Takeda air intake help
Old Apr 30, 2017 | 04:36 PM
kabbage's Avatar
Bought the Takeda intake forgot I have the round mass air flow sensor can you switch that out or not. Have a 2003 G35 Sedan was looking for a short ram intake. Any help would be appreciated.
Old Apr 30, 2017 | 08:20 PM
gary c's Avatar
If at all possible take/send the intake back to the seller! Those type of intakes will turn your sedan into a major slug! Our G35s love cool/cold air, those intakes allow your car to breathe nothing but hot air causing loss of HP! Trying to get more air into your plenum, buy a AMSOIL drop in dry filter for the best filtered air possible!
Gary
Old May 1, 2017 | 10:27 AM
kabbage's Avatar
Thanks Gary I have a drop in K & N right now are those ok? Also if say I wanted a cold air intake what would you recommend or is the stock air intake the best option. I will be sending the takeda back.
Old May 1, 2017 | 04:05 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
The factory intake is a cold air system. The z-tube helps a bit. Straight through design vs the added resonator of the G35.
Old May 2, 2017 | 12:23 AM
Urbanengineer's Avatar
So if we plugged the resonator would it effectively be a heavy Z tube?
Old May 2, 2017 | 09:34 AM
gary c's Avatar
Kabbage, you have all you need to get cooler air into your plenum! However, Stillens cold air intake and z-tube combination is the only intake mod that doesn't cause WHP loss. Regardless of what manufactures claim there are no HP gains from intakes on our G35s, FYI...Gary
Old May 2, 2017 | 02:50 PM
kabbage's Avatar
Thanks again
Old May 2, 2017 | 04:06 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Or cut it off then plug.
Old May 2, 2017 | 06:44 PM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by gary c
However, Stillens cold air intake and z-tube combination is the only intake mod that doesn't cause WHP loss. , FYI...Gary
Not so fast my friend, the R2C intake seals against the hood so it just takes in air through the open front from the grill plus they have the best dry filters on the planet.
Old May 4, 2017 | 01:44 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Pretty expensive though. Summit sells the filter and heat shield and reuses your stock intake tube (Z-tube in my case) for $150. Good deal?
Old May 4, 2017 | 08:52 PM
Blue Dream's Avatar
Yep I'd jump all over that deal as the filter and enclosure work all the magic. Their "R2C tube" looks nice but does the same thing as a z-tube. I run a chromed version of a z-tube with my R2C.
Old May 5, 2017 | 07:06 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Ordered, let you know how I like it when it arrives. Then I need to schedule a tune.
Old May 6, 2017 | 07:32 AM
Blue Dream's Avatar
Cool I think you'll like it a lot.
Old May 6, 2017 | 09:15 AM
gary c's Avatar
Discussing air intakes ideas...SLICK runs a Fujita intake with a AMSOIL cone filter. I removed all the brackets from the inside of the drivers side front fender so there's no restriction. Her KurumaZ front bumper picks up air from the left front vent. Much better than breathing all that hot air under the hood!
Gary
