Help!: Need to source a CORRECT '04 aux fan motor
Old Sep 3, 2017 | 11:29 AM
Tim Schuh's Avatar
I have a 10/2003 '04 Sedan and the aux fan motor finally gave up the magic smoke and quit working. I bought what was SUPPOSED to be a direct replacement for the OEM but this crappy TYC motor is obviously for later models that are pullers. Mine is a pusher so the motor is spinning in the wrong fricking direction. Having gone through two different vendors promising the correct part and both sending me the exact same WRONG part, I need help from the community.
Any help would be greatly appreciated. Thanks very much in advance.
Old Sep 3, 2017 | 04:02 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Call the infiniti dealer, run your VIN, have them give you the correct part number. Just because your vehicle was sold in '04 and licensed as an '04 DOES NOT MEAN IT'S ACTUALLY AN '04.
My "2012 ford focus" is a 2011 on paper (bought in october for the new model year release) a complete redesign and no 2011 parts will fit on this vehicle so...
Old Sep 3, 2017 | 09:08 PM
Tim Schuh's Avatar
Yep, that's why I included the build date in my original post. I noticed that different vendors show a driver's side and passenger side fan motor while some also include another part number that doesn't distinguish. In the end, they all seem to be the same TYC P/N.
Old Sep 3, 2017 | 09:21 PM
cleric670's Avatar
BANNED!!!
Is this the configuration of fans? This is an actual dealer and their diagrams are correct.
https://www.infinitipartsonline.com/...oling-fan-scat
EDIT: also appears to use a different configuration of fans depending on coupe/sedan?? Did the coupe not get the belt-driven fan at all?
Old Sep 4, 2017 | 12:42 AM
Tim Schuh's Avatar
Unfortunately not. I have a mechanical belt driven radiator fan and a pusher aux fan. Every fan motor I've found so far is a puller.
https://www.infinitipartsonline.com/...or-92122wl00a/
However, every cross reference I've found so far for that part gives the WRONG motor. They source the same TYC puller motor which of course spins the pusher fan the wrong direction. Mechanically they're the same but electrically, not so much.
Old Sep 4, 2017 | 01:39 AM
cleric670's Avatar
BANNED!!!
Call wrecking yards in your area and see if they have a used one, then you can verify which side of the radiator the fan is mounted.
If you have a belt-driven fan, then the aux fan you are looking for is an early '03 G35, not the later '03 or newer. Also have the option of deleting the pulley-driven fan and going with a double puller, iirc there's a DIY around here somewhere for that.
Old Sep 4, 2017 | 09:25 AM
Tim Schuh's Avatar
Good to know, thanks Cleric. Seems like that was one point Nissan couldn't quite make their mind up on at that point in time. Unfortunately that means I either get one from a wrecking yard as you suggested or pay close to $200 for a new one. Still cheaper than an overheated engine but I was hoping to find a less costly alternative to a piece of unobtainium.
Old Sep 4, 2017 | 11:30 AM
cleric670's Avatar
BANNED!!!
The motors are individually replaceable so you don't need the whole shroud and fan blades. A nissan or infiniti dealer should be able to give you the correct part # based on VIN and then you can order them through rock auto.
http://www.rockauto.com/en/catalog/i...fan+motor,2164
Another viable option is to have the motor rewound, anyone that rebuilds starters / alternators in your area can rewind a motor.
Old Sep 4, 2017 | 01:55 PM
Tim Schuh's Avatar
Despite what Rock Auto, Parts Geek, etc. believe, that motor is exactly what I have and is not correct. That very part is what started me down this road in the first place. Nearly as frustrating as sourcing BMW parts.
Old Sep 4, 2017 | 04:04 PM
Tim Schuh's Avatar
P/N 92122WL00A
If you look at the drawing that RockAuto has (wish I had originally) you'll see they indicate clockwise rotation. The fan is designed for counter clockwise rotation. The drawing also disagrees with the fan blade pitch. If the fan they have does indeed turn clockwise then their part makes sense in that application however it does not work with the fan I have currently.
Old Sep 4, 2017 | 04:10 PM
cleric670's Avatar
BANNED!!!
Yeah I'd be looking into a motor rewind then, if you don't have a starter/alternator rebuild shop then call around to various electrical shops. Someone has to know who does motor rewinds.
Old Sep 4, 2017 | 04:12 PM
cleric670's Avatar
BANNED!!!
Ohhh crap, I totally brainfarted, it's a DC motor, just swap the polarity of the leads to reverse the motor!
Old Sep 4, 2017 | 04:34 PM
Tim Schuh's Avatar
It's a multi-speed fan though. How will swapping the first stage impact the rest of the modes? Please forgive my ignorance here.
Old Sep 5, 2017 | 11:32 AM
cleric670's Avatar
BANNED!!!
You're talking about the radiator fan right? It's either on or off depending on the relay controlling it, not multi-speed unless I'm completely off my mark.
Old Sep 5, 2017 | 03:48 PM
Tim Schuh's Avatar
No, I'm talking about the aux (a/c condenser) fan on the driver's side (LHD). My radiator fan is belt-driven.
