Engine swap time!
Old 10-07-2017, 12:11 PM
eazdaskeez's Avatar
Updates!
Been super busy with life and everything thing else but things are looking up! Wife picked up a new job so now I can get more car goodies!
Engine delivery got delayed but I finally got it today. Well went to take a look at it rather.
Shop says 97k but doesn't look like it at all.
Valve covers are leaky which is to be expected, didn't pull the plugs but oil looks fine. Tommorow I'll be grabbing my friends pickup truck to bring the engine home and clean it up some and pull the valve covers and do a good once over before I start the swap.
Old 10-07-2017, 06:47 PM
cleric670's Avatar
BANNED!!!
Received 2,473 Likes on 2,164 Posts
Coupe 6MT Premium RAS
Pretty common looking motor, I'd go through ALL the harnesses and unplug them to make sure they aren't corroded inside, depending on overall condition you might keep the TB/intake, some harness stuff, etc from the original motor. Usually they just use hydraulic shears and literally CUT every connection to the motor, unbolt the motor mounts and yank it out as fast as humanly possible.
Old 10-08-2017, 06:18 PM
eazdaskeez's Avatar
Phase one has begun
​​​I'll start off by stating that I have basic mechanic knowledge due to growing up around cars and my dad who loved cars. As I grew up I gained more knowledge and here we are today.
So removing the front end is pretty straight forward so I'll sum up the easy parts.
Remove bumper
Remove reinforcement bar which is held in by six bolts on each end.
Next Remove front fan (if you have one)
Next up is the horns which are located to the left of the fan
Then remove the hood latch that is held on by three bolts
Next I removed the headlights and Jacked the car up (jackstands are the only way you should support the car) to remove the coolant so the radiator can be removed but before then you have to remove black the plastic covering that shielding the radiator and condenser.
It's held on by two bolts in each side on the top that are 12mm and you have two on each side that is right beside the fender liner
Now you remove the shield and can drain the coolant and remove the radiator and Watch out for transmission cooler lines at the bottom.
*had my little helper with me as well lol.
Separate the radiator and the Condenser and you've completed phase one!
Two things I got stumped on that I will research later.
Removing the hood latch cable so I can freely remove the plastic shield and moving the condenser out the way so I don't break the lines.
Other than that it was pretty uneventful (minus the coolant spill lol).
Phase two will be up in a few days.
Old 10-09-2017, 02:50 PM
FreshLikeAG's Avatar
Thanks for sharing your work. Love seeing projects like this
Old 10-09-2017, 08:16 PM
eazdaskeez's Avatar
Phase two! I'm back folks
Had a buddy come past and help me out with the offering of beer and food lol.
Okay it's Connection removal time.
​​​​​Remove all connections from the top of the engine such as coils, throttle body, and anything else you see accessible.
Remove the grounds on the timing cover and any brackets you see.
There's some hidden sensors that won't be visible so I'm here to give ya the scoop on those.
Ac compressor has two connections, one on the top and one and the bottom so be sure to remove those.
There is a connection by the oil filter, power steering and alternator.
That's the alternator connector
Oh and here's a well needed tip.
The power steering AND ac compressor and condenser and be pushed to the side so no draining power steering fluid or dealing with the ac system
The drivers side has a ground hidden on the firewall but that can be unplugged. Passenger side has quite a few connections which are on the top so its pretty visible. You also have the fuel pressure regulator held on by two bolts and remove the hose as well.
On the rear of the engine you have two firewall coolant hoses the two camshaft sensors and one big connector (haven't removed this yet).
Bottom? Fun times my friends. The cat bolts have to be removed. I opted to removed the ones closet to the manifold and I HIGHLY suggest a swivel connector, it will make thing's so much easier.
Also while your down there you should remove the motor mount bolts. There is one on each side and it's a 17mm.
Next remove the starter Which has 2 14mm bolts and a ten mm nut for the battery cable.
After that i would start removing the transmission case bolts. The bolt ones are 14mm but as you get towards the middle they turn into 17mm. Also there's a crankshaft sensor that should be removed from the bottom of the transmission as well.
I think that's about it, I only have the top Trans bolts, the firewall hoses and that big connector on the rear and it should come out smoothly!
Edit. Engine is out but wanted to add a few notes.
Watch out for the trans cooler lines located on the side by the oil filter. They will stop you from removing the engine and can easily be removed by taking off the two ten mm bolts.
Old 10-10-2017, 03:43 PM
eazdaskeez's Avatar
Update.
Went and picked up the engine and pulled the plugs to get and general idea of how it was running and they looked pretty even all across
Next up is to drain the oil and pull the filter and cut it open to see if any debris is caught in the baffle. Also need to change the valve cover gaskets
Old 10-10-2017, 05:40 PM
cleric670's Avatar
BANNED!!!
Is that oil on the spark plug at the point where the ceramic meets the metal? 3 of them have an orangish looking ring around the base of the ceramic.
If it's scorching then it's something to keep an eye on, fuel pressure regulator might have been wonky.
Old 10-10-2017, 05:49 PM
eazdaskeez's Avatar
Yea the typical "Corona stains" as some like to call it. I'll swap my fpr over since I didn't have that issue
Old 10-12-2017, 04:04 PM
eazdaskeez's Avatar
Small update.
Weather has been crappy so it's been at a standstill. I did manage to pull the upper intake off and it's quite clean so that's good.
​​​​​​This sat its supposed to be nice and sunny so I'm hoping to be done by Monday.
So as far as the checklist for the replacement engine oil change, fresh coolant, fresh plugs.
Should I use cheap oil then drain the engine?
Old 10-13-2017, 06:13 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,487 Likes on 1,222 Posts
Not a bad idea, especially if the engine hasn't been run in a while.
Old 10-14-2017, 07:36 PM
eazdaskeez's Avatar
Well folks I'm Back and we are good to go
So engine is out without too much trouble and I wasn't aware that the new engine didn't have an torque converter attached to it. So my new issue is
How the hell do I reach these bolts for the torque converter?
Old 10-15-2017, 02:05 PM
cleric670's Avatar
BANNED!!!
Access plate is in the upper oil pan I think, single bolt holds it in place then you can rotate the engine to access those drive plate (flex plate) to flywheel to torque converter bolts.
Old 10-16-2017, 01:14 PM
eazdaskeez's Avatar
Found the plate and hoping for the engine to be in today or in the am. I'll be starting a part out thread with the old engine if anyone needs anything. Maybe I can help some folks out because you've guys helped me so far!
Old 10-16-2017, 05:53 PM
eazdaskeez's Avatar
Tq is now mated to the trans and fully seated. I'm assuming you should feel slight resistance when turning the tq. Question is how do I reattach the bolts to the tq and the flex plate once everything is back together? I'm assuming through the same opening that I used to access the bolts?
  #30
Old 10-16-2017, 06:35 PM
cleric670's Avatar
BANNED!!!
Yep, just do something to stabilize the crank from the front of the engine, don't pry on the flywheel teeth to keep it from turning.
