HELP ME with these CODES
Old Oct 30, 2017 | 07:09 AM
karmakenja21's Avatar
Where do I start at with all these codes coming up? Car has a number of problems radiator fans are not coming on car runs hot.....VDC /Slip light on (car has 4 new tires 4 new rotors front/rear brakes are new) stays on while driving ....air bag light blinks..
Last edited by karmakenja21; Nov 27, 2017 at 08:56 AM. Reason: Took the car up to Infiniti they code the VDC and slip light they told it was a bad fuse on the car and they told me to monitor my Check engine light if the light comes back on bring the car back up
Old Oct 30, 2017 | 03:18 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Start bygetting the battery tested, cleaning the battery terminals, wire lugs (both ends), and resetting the codes. You could have a cascade failure of systems related to a battery problem.
Next tackle safety related ones like the SRS being disabled, you will probably need a trip to your local Nissan dealership because there are a lot of components. Steering error could be the steering angle sensor which might be causing all the VDC and traction control errors.
