Mechanic used an off brand of transmission fluid. Do I need to be concerned?
Old Nov 23, 2017 | 12:22 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
As long as it passes the test for plastic erosion, heat resistance, pressure degradation, and has good quality detergents it will probably be fine. There are a LOT of good hydraulic fluids on the market but there are also a lot of really shitty ones too and when your mechanic is using "mystery fluid" that was probably the cheapest **** he could get his oily paws on then you're just asking for trouble.
It's also rare, but sometimes there's compatibility problems when you use 6qt of one fluid and 4qt of another. The only real problem I've seen is separation of the two fluids when the transmission is cold and it causes wierd shifting until it's fully up to temp and the fluids have "homogenized" again.
Nissan Matic-S has a reputation for working perfectly in these transmissions which is why it's usually the recommended product.
Old Nov 23, 2017 | 08:10 AM
G2B35AGN's Avatar
will ensure your transmission lives a long and healthy life, likely being the final component to fail before it is swallowed up in the abyss of wrecking yard vehicles destined for scrap metal in a Chinese foundry, to once again be reunited with it's brethren as liquid magma steel and eventually be reincarnated as an I-beam or something even cooler....
The End
Buddists should probably not venture into the Politics sub-forum.... There be monsters lurking....
Old Nov 23, 2017 | 08:46 AM
cleric670's Avatar
BANNED!!!
HAH! I didn't even make the connection when I wrote that.
Old Nov 23, 2017 | 09:04 AM
Urbanengineer's Avatar
Legendary haha. Well put. Good luck OP.
Old Nov 23, 2017 | 04:22 PM
BradMD_96's Avatar
When I replaced my engine I put back Valvoline in the transmission. It's been shifting great over the last 10k+ miles of spirited daily driving. It does also meet the JASO A1 standards.
$90 sounds good for trans drain/fill from the dealership
Old Nov 24, 2017 | 10:25 AM
gary c's Avatar
Originally Posted by KingRat
I was doing some reading and I thought I read flushes were bad for these transmissions and they only recommended draining?
There's a good possibility that what you have circulating in your AT is doing damage and it's mixed with the fluid you were supposed to use! You could do a drain/fill now and again in a month which should remove most of the unwanted fluid. Flushes, good or bad depends on who you're asking.
Gary
Old Nov 26, 2017 | 11:58 PM
TurTLe*'s Avatar
OP,
I would honestly no worry about it. Matic S wasn't even invented when your car came out.
Those 4 QT already mixed in with your fluids so you can really UNDO anything. Just drive it, I dont remember how much mileage you have but most are 100k+ if the tranny starts to slip it was time to go anyways. And i highly doubt it.
I changed my fluid about 8 years ago and 4 years ago. Both times i've used Castrol import ATF. Honestly Matic-J was made by Castrol and possibly Matic-S. At the time i had 60k and was out of powertrain warranty so i said screw it. I'm at 130k now and no issues.
Having worked at a dealership in the past, i can promise you.... in many cases non nissan fluid has been used.
Parker6
Sep 29, 2012 10:03 PM
-j.C-
Drivetrain
Dec 18, 2010 04:46 AM
foxx_good
Jul 29, 2009 07:27 AM
AleksCBR
Nov 13, 2008 09:15 AM
G35inSD
Feb 27, 2007 04:38 PM
