G35x front axle question
Old Jul 8, 2018 | 07:46 AM
Samahi72's Avatar
Started off by just changing my struts when I noticed the passenger side inside CV boot was toast and the joint is bad. Is there anything special that I need to know about before I remove the axle? Is it bolted on or will it just slide out? Also what size is the axle nut? I have a 1 1/4 inch socket that seems to fit but what is it in metrics? I am thinking it might be a 32?
Thank you
Old Jul 8, 2018 | 11:45 AM
jbarnett250's Avatar
Thank you
The passenger side isn't bolted in. You can pry it out. There is a good diy on here somewhere. I used it a couple years ago to do mine. Search and you'll find it.
Old Jul 9, 2018 | 11:47 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah there's an internal snap ring that pops out when you apply enough pressure to the CV axle, personally I use a little pry bar and a deadblow mallet. It doesn't take much to get them to pop out I'm sure you can look up a youtube video on it.
Old Jul 10, 2018 | 01:04 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
36mm socket for the axle nut. I replaced mine with cheap o ebay units and the driver side didn't fit until I used an angle grinder to clearance the bolt head area. Passenger side fit great. Get what you pay for I guess.
Old Jul 10, 2018 | 07:49 PM
Blue Dream's Avatar
I drove ttrank's car solo
IIRC the axle nut is torqued to something like 177 lb/ft and can be a pain to get off. I used a breaker bar with part of a jack handle on it to give it more force. I had to stand on the damn thing to get the nut free the first time I took off my half shafts.
Old Jul 12, 2018 | 10:47 PM
coffeysm's Avatar
Check out raxles.com. I haven't used them personally, however, I've heard great reviews on some other sites. They're remanufactured OEM parts by people here in the US for like 10-20 years and not some Chinese cheap part.
Old Jul 13, 2018 | 03:45 AM
Blue Dream's Avatar
Rockauto also sells reman axles but their supply changes all the time.
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
munkle
Oct 11, 2013 09:39 AM
davidalindsey
Drivetrain
Apr 21, 2013 06:00 PM
tutty
Drivetrain
Jul 27, 2012 06:11 PM
iiiiiekoiiiii
Sep 15, 2011 01:44 PM
