Injectors - While I am in there......?
Received 2,459 Likes
on
Coupe 6MT Premium RAS
Fuel injector clips are pretty much standardized even though all manufacturers have their own. You should be able to find them at ANY parts houses.
https://www.z1motorsports.com/fuel-r...p-p-10593.html
The OEM part number is on this website as well.
If they're not bent at all then I typically just reuse them, the problem is they get damaged sometimes when uninstalling because everyone has switched to cheap stamped grade5 steel instead of high tension spring steel like older injectors used.
THMotorsports
Engine-Vendor
07-10-2014 07:27 PM
tibasnatch
05-15-2012 12:04 PM
Boost-Geek
Engine - Power Adders
19
09-10-2011 05:10 PM
willcho415
06-28-2009 08:17 AM
sales
11-13-2005 11:14 PM
