"VDC OFF" & "SLIP" light came on
Old Aug 26, 2019 | 07:29 PM
J Doloz's Avatar
05 G35 6mt sedan
I have and 05 G35 6mt sedan and the VDC off and slip light came on At the same time and don't know how to turn them off or is there something I need to replace if someone could help me out pls btw it's been a little over 1 month it's been on and the car still drives normal but the interior dash light with the exclamation point in parentheses comes on after I've been driving for like 20 minutes but when I turn off the car after getting to my destination and start my car again the exclamation light is gone BUT will come on again pls help
Last edited by J Doloz; Aug 26, 2019 at 07:44 PM. Reason: Forgot to mention some other things
Old Aug 26, 2019 | 08:25 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Check your alignment and front end suspension. I had that issue, turned out my LCA's were pretty shot and when going straight, the steering wheel tilted left.
Old Aug 26, 2019 | 08:41 PM
J Doloz's Avatar
05 G35 6mt sedan
mine doesn't though
Old Aug 27, 2019 | 02:04 AM
Scorpi0's Avatar
Is the check engine light on too?
Old Aug 27, 2019 | 02:56 AM
J Doloz's Avatar
05 G35 6mt sedan
No it isn't just the VDC off & slip light are on...and the REV light but that is always on it has a rev up engine
Old Aug 27, 2019 | 05:55 AM
Scorpi0's Avatar
Ive heard it can come on due to low brake fluid. Weird....I know.
Old Aug 27, 2019 | 08:50 AM
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
Worth a check, always like checking the easy stuff first. My experience with Toyotas and other vehicles, low brake fluid usually triggers the parking brake light.
For the OP, definitely get a good code scanner that can read ABS codes and see what it is pulling. My first inclination would be an ABS wheel speed sensor or ABS ring gear issue at one of the wheels.
Old Aug 27, 2019 | 10:11 AM
fitgineer_93's Avatar
First, check your brake fluid level.
Second, read up on the hundreds of threads on this issue!
Old Sep 23, 2019 | 02:36 PM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Very possible you have a clockspring going bad under the driver's airbag. Do not use anything other than an OEM part if that's it but you'll have to have the VDC reset after it's put in. A/M clocksprings are available cheap but they're made wrong and don't work. If your steering wheel control lights are going out it'll fix that too.
Old Sep 25, 2019 | 02:15 AM
coffeysm's Avatar
Do you have RAS on your car?
