How a Hydraulic Power Steering Rack Works
Old Nov 18, 2019 | 07:01 PM
speedkar9's Avatar
Infiniti G35
Here's how a hydraulic power steering rack works:
Here is the steering rack removed from the car. It forms part of a hydraulic circuit that aids the movement of the steering rack when the wheel is turned.
Inside the pinion gear housing is the rotary valve:
This is the spool which collects the fluid into different channels and redirects it according to which side you are turning:
Inside the rotary valve housing are the holes for the hydraulic lines that correspond to different channels on the spool.
The rotary valve consists of a small torsion bar that twists a few degrees. This twisting action is what redirects fluids through the spool to either the right or left side of the rack piston:
Enjoy!
Old Nov 23, 2019 | 08:27 AM
Urbanengineer's Avatar
Wow. Glad I just paid for a reman when mine started leaking . Nice piece!
raymondgor
Apr 30, 2011 12:12 PM
DrewQ1
May 11, 2009 03:40 PM
g35panama
Jun 14, 2008 02:34 AM
