Need help finding a decent replacement pipe for my 04 g35x, have soaked the thing so many times and no progress. Plus the bolt looks like it was stripped by the previous owner so I can’t get any grip along with the rust holding it so I have to go to plan B and replace this line too, but only problem is I can’t seem to find a decent replacement on where on the web. Does anyone know where I can find it at? Or a solution to get this out? Thank you
it's been a few years now. did you ever figure out what this part is or where to find it?
it’s been so many years I don’t recall exactly my method of fixing it since I sold it a few months after. I believe I let it soak for like 2 weeks and I eventually grabbed channel locks and got it opened. It should be more than long enough though you could find it at the junk yard ever since the takeover movement there’s plenty of parts these days. You could also just buy 2 feet of brake line and autozone and a cutting/ flaring kit for brake lines off Amazon and cut that entire section off and just get a new rubber hose if that connectors rusted and you can’t get it off.
