Changed spark plugs now it just cranks! HELP plz
Old Aug 16, 2020 | 09:58 AM
TonyG18's Avatar
g35x sedan AWD
Unhappy Changed spark plugs now it just cranks! HELP plz
Alright so this was my first time changing my spark plugs or ever really working on a car. So I started on the driver side an did one at a time no way I switch up any wires to the coils. I installed the new ones and the car started but maybe a min or 2 it died so I tried to crank it again an it just cranks over an over....I checked all connection everything looked fine so I changed back to my old plugs and the car started once again.. I shut it off took the spark plugs back to autozone and got my money back ordered oem ones. Got back home started the car again and it started back up stays started for about 2 mins then died again an now just cranks...
Old Aug 16, 2020 | 11:23 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like you ran out of gas, don't rely on the gas gauge which is notorious for failing and showing a half tank when you're actually empty. Add one gallon of fresh fuel and see if it runs.
Old Aug 16, 2020 | 11:24 AM
cleric670's Avatar
BANNED!!!
If that's not it then plug in an OBD2 scanner and check for hidden codes, might be a cam/crank sensor failing.
Old Aug 19, 2020 | 06:09 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Check all your ground points + the sub harness connectors to the coil packs.
lilDee
14
Feb 26, 2009 02:20 AM
GMoNeYAir23
Jul 19, 2008 10:34 AM
High3nd_SD_g35
Jun 16, 2008 03:50 AM
cutiewolf
Feb 24, 2007 12:07 AM
