Aluminum Pedal Cover Installation
Aug 23, 2020 | 12:10 AM
Got these last year thinking they would be a simple mod to spruce up the interior. I was wrong.
The clutch and brake are impossible to put on because they are barely bigger than the actual pedal.
Enough blood, sweat, and tears. I will pay someone to put them on. Don’t trust a “shop”. I am dead serious
Hit me up if you can make it to Stockton, CA
06 G35 Sedan 6MT
Little f**kers
Reply 0
Aug 28, 2020 | 05:21 PM
This is a pretty simple install. Just heat them up (don't melt them, hair dryer works or leave them in the hot sun for a bit) and then use a screw driver to help pull the rubber around the metal. Wrap the screw driver in electrical tape if the sides are too sharp to avoid damaging the soft rubber.
Reply 0
Aug 30, 2020 | 05:57 PM
Trust me I’ve tried that and every technique on these boards (I boiled them!) I even put soap to grease them up didn’t work. Tried this 3 times already.
Reply 0
Aug 31, 2020 | 01:15 AM
Shave the sides off your original pedal.
Reply 0
