I need help overheating problem
Hi there I need help
like really need
I have g35 2006 aautomatic sedan with tuneup rev-up
I did all ready
New radiator, thermostat, water pump, fan, coolant sensor.
So I start the car i let him warm up
after i drive around 15 minits and start over heating not like H
Only one line after a little more until get the line before H
and another think I saw
it is when I'm driving and I put the shifter and I go high rpm is cooling down
and when I go low rpm or higher gear is getting hot
Please can some one help me with this or have any ideal
like really need
I did all ready
Most likely air in your cooling system?
Did you replace the radiator cap and are your fans working properly?
If you used cheap aftermarket parts you may have a defective water pump and or thermostat?
lemmy999
Mar 9, 2018 08:03 AM
