no sound from radio factory bose stereo g35 03 sedan
Old Mar 2, 2021 | 11:06 PM
spykegtp's Avatar
g35
I have a 2003 g35 sedan, I have had this problem for a while now but it has gotten worst lately. The radio works fine every time I leave the car overnight, and the sound works for a few hours, but then when I try to lower or raise the volume it stops, or the volume number in the radio changes but it doesn't affect the speaker actual sound. Once the sound stops I try to raise the volume all the way up or all the way down and all I hear are random speaker pops or only sound from one side of the car. Also sometimes the volume is stuck at a specific level, and even though the radio shows the volume number changing, the actual sound stays the same. So I am assuming the speakers are not blown out because otherwise, they wouldn't sound at all. I replaced the amp with another stock bose amp that I got from a junkyard but still have the same issue. Any recommendations?
Old Mar 5, 2021 | 06:49 AM
Scorpi0's Avatar
Pretty sure the head unit is the problem.
Old Mar 5, 2021 | 07:59 AM
telcoman's Avatar
Veteran: Army
Originally Posted by spykegtp
I have a 2003 g35 sedan, .... Any recommendations?
Bench test it!
Any good quality automotive audio shop would be a better solution for you rather than guessing and just throwing parts, wasting time and money.
Good luck
Nism0r
Jul 29, 2021 12:23 PM
jeanzpaul
Aug 26, 2012 02:20 PM
Blacklite
Dec 29, 2011 11:40 PM
daveatbenson
May 7, 2009 12:02 PM
