Where to Buy Fuel Pump Relay???
Old Oct 26, 2021 | 01:26 PM
adamfrom's Avatar
G35X Sedan A/T
Fuel pump relay went out on my 2006 G35X A/T Sedan. Resistance was 150 ohms on the coil so I know the relay is the issue. I’ve checked all of my local parts stores, nobody carries this relay. The dealer wanted to change out the entire fusebox for $1500. does anyone know where I can go to get a fuel pump relay? or are there any other relays that are interchangeable?
Old Oct 26, 2021 | 04:09 PM
telcoman's Avatar
Veteran: Army
Have you followed the troubleshooting steps in the FSM?
https://www.nicoclub.com/service-man...F2006%2Fec.pdf
See page EC-663
Good luck
Old Oct 26, 2021 | 08:16 PM
adamfrom's Avatar
G35X Sedan A/T
See page EC-663
Good luck
EDIT: Replaced the fuel pump relay with the high beam relay, and the car started. Still no clue where to buy the IPDM generic Nais ACM33201 Relay or aftermarket equivalent to replace my high beams.
Old Oct 26, 2021 | 10:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just take the malfunctioning relay down to a local pick-n-pull and start digging around through basically ANY 2000-2015 Nissan and you'll probably find a matching relay.
I'm shocked that these parts houses you went to didn't carry that relay, it's the 4 pin relay yeah? Those things are EXTREMELY common, I think it's the same relay used for the starter, the high and low beams, fog lamps, throttle body, ECM power, ignition on.
Old Oct 27, 2021 | 01:45 AM
05_SkylineSedan's Avatar
20 Year Member
This might be it:
Amazon Amazon
Calipat916
Jan 14, 2016 02:43 PM
KeepinItG35
Nov 17, 2013 08:45 AM
GaleForceWinds
May 16, 2012 09:31 AM
rocsell
Sep 19, 2007 11:22 PM
