trasmiccion
Old Mar 20, 2022 | 07:07 AM
D.J Ortiz's Avatar
G35
trasmiccion
The AT Check light came on. turn off the car now it does not want to turn on and when I put the scanner to read it does not connect it does not read,
Old Mar 20, 2022 | 10:56 AM
Scorpi0's Avatar
Disconnect the battery for a few minutes to see if it might reset the ECUs.
Old Mar 20, 2022 | 01:35 PM
D.J Ortiz's Avatar
G35
AT light on
I already tried it but nothing, the strange thing is that the car does not even start
Old Mar 20, 2022 | 06:29 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
So you're saying the engine won't CRANK when you turn the key to START ?
Old Mar 20, 2022 | 09:07 PM
D.J Ortiz's Avatar
G35
yes, and already check the starter and the fuses
Old Mar 21, 2022 | 01:01 PM
fitgineer_93's Avatar
Do you have a U1000 code?
Old Mar 21, 2022 | 01:04 PM
D.J Ortiz's Avatar
G35
no because when connecting the scanner it fails to make a connection that's the other thing I don't understand
Old Mar 25, 2022 | 06:47 PM
cleric670's Avatar
BANNED!!!
I would unplug the battery, pump the brakes, then let it sit 10 min. Reconnect the battery, then see if the scanner will connect.
Also verify the battery is FULLY CHARGED by putting it on a charger.
netsrak1998
Jul 18, 2018 05:10 PM
patrickr_93
Lighting
Mar 14, 2014 10:42 AM
in2win
Oct 28, 2007 11:34 PM
carbon
Jul 11, 2006 01:36 PM
