Low idle
Old May 26, 2022 | 12:41 PM
AWDg35's Avatar
04 G35x sedan
Low idle
Hello everyone I will get straight to the point. I have an idle issue. Here is all information on what's been to the car since I purchased to fix. There is new coil packs from oriellys and OEM NGK spark plugs gapped to .044. I have also put new valve cover gaskets and new OEM valve covers. I have relearned the throttle body and ECU after doing so. All vacuum lines have been properly hooked back up. The idle is sitting at 400 in park, but my reader says it is at 725-737. Fuel injectors have been cleaned as well. The only other thing that was done is a muffler delete and it was previously done by previous owner. I'm stuck at this point and just need some guidance from here.
Old May 27, 2022 | 08:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check out the FSM section EC - Engine Controls, under "basic service procedures" has the steps for recalibrating the idle air algorithm.
https://www.nicoclub.com/infiniti-service-manuals
tripletrouble
Jul 29, 2022 11:06 AM
Veronatron
May 14, 2020 11:36 PM
John101300
Oct 18, 2018 04:07 AM
spacecitygroove
Jun 27, 2014 01:13 AM
chevelle100
Nov 28, 2009 01:58 PM
