Harness question.
Old Sep 9, 2023 | 07:33 PM
romansan2008's Avatar
Harness question.
I have a 2006 g35 sedan rev up 6 speed
i severely moded my cars interior.
added:
OEM Infiniti nav
auto drivers seat and electric column
auto headlights
all 4 auto windows
dual zone climate control
rewired my stereo fully
My car didn’t come with any of the stuff or partial like only front windows where auto but not rear.
anyone know where I can find wire harness part numbers with select options.
I did make my own harnesses and ran them along the OEM harness but for some reason I want to clean it up and want to find the harnesses with select options (all that can be in a 6 speed) so I can remove old harness and my additions and replace it with OEM one.
I actually wanted to add the smart key option but according to manual my ecu/BCM does not support it and needs to be an auto trans car.
I’ll try to call dealer and ask them but I don’t think they will be able to help without a vin number.
my vin will not help them locating a harness for the options I added to the car.
thank you all,
roman
Old Sep 9, 2023 | 07:36 PM
Mostly interested in dash harness, left and right harnesses.
dash harness need to have the OEM nav plugs and steering column plugs
side harnesses need to have the auto driver seat plug (12 pin, not mine that only had 4 pin) and door with auto windows plugs.
I do not care if it’s a Bose stereo harness or not.
if you can help or have questions let me know.
Old Sep 10, 2023 | 11:10 AM
05_SkylineSedan's Avatar
20 Year Member
Good Lord romansan, you've put a lot of work into your car. And if all those mods are already functional, the idea of swapping out the harnesses for OEM makes my brain hurt. That would be a mod that nobody but you would know about or see. That sounds downright punishing.
But you gotta do what you gotta do. So ... I would think you should look for harnesses from parted-out cars that might fit the bill. But it will be complicated by the options you're looking for and I would suspect you might find some that will almost work but still need to be customized.
Another way to go would be to get into dressing your own hand-made harnesses with items from a place like this:
https://www.wirecare.com
Old Sep 10, 2023 | 11:28 AM
It started with the all 4 windows being auto not just the front 2, I asked the dealer about it and they told me it can’t be done.
so I took my time to learn the difference in wiring and made some changes. Changed window motors and door harnesses and front drivers window switch and harness mods to tie in the rear doors.
it rolled down hill from there.
auto headlights was next
then I started to get dual zone climate to work. That was fun.
my last was the auto drivers memory seat and electric column.
so my car is now 2006 Infiniti G36 Sedan premium sport track lol
ill check out that site.
I know there are Infiniti with all the mods I made at least by the can network diagram in workshop manual.
oh I did have to change out the cluster from non nav version to a nav version. OEM nav didn’t have fuel economy screen functionality till I got a new nav cluster and moved my miles to it.
used VVDI PROG for the programming.
I just love a challenge I guess.
Eurog35
Dec 9, 2014 08:27 PM
App6MT
Dec 1, 2008 03:49 PM
