Reading ECM Harness voltages
Old Nov 29, 2008 | 06:53 PM
App6MT's Avatar
Littering and...
So here's the diagram from the service manual:
I'm trying to check the voltages for the "Power Supply for ECM", which is pins 119, 120. The manual states that it sound read 11-14V with the Ignition Switch: ON.
Also, 121 is the backup for the power supply, which should read 11-14V with the Ignition Switch: OFF.
Ok so my question is, do I read this directly from the harness? What I did was disconnect the harness from the ECU, and try to test the actual connector. However, it doesn't seem to be working that well. So do I need to plug the harness back into the ECU and tap into the individual wire?
Old Nov 29, 2008 | 09:01 PM
App6MT's Avatar
Littering and...
The answer is you can check it with the ECM harness taken out of the ECM.
Problem was with the wiring diagram was completely *** backwards from what the actual harness looked like.
Old Dec 1, 2008 | 03:49 PM
str8dum1's Avatar
ya, took me a while to figure the pics are backwards when I was trying to trace my back IVT solenoid control.
Danielek
May 1, 2022 01:28 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
yosip1115
16
Sep 28, 2015 04:14 PM
vamarris
Sep 26, 2015 12:56 PM
