6MT owners, how high do you RPM??
Old Mar 14, 2005 | 02:32 AM
BobbyG123's Avatar
Now that I'm past my break-in period (1600 mi) I'm curious how much I can (occasionally) crank the RPM's without causing any longterm damage. The "growl" is so deep when I get to 5K RPM that I often chicken out and shift. I'm looking to have a little fun with my baby without doing any harm. Like most people, I enjoy clicking through 2nd-4th gear pretty hard on occasion.
Thoughts???
Old Mar 14, 2005 | 03:02 AM
doogie's Avatar
Depends how you like to drive. I'd say I hit the redline daily when I get to the quieter roads (well, they're quiet before I arrive )
Old Mar 14, 2005 | 03:51 AM
Nickk6's Avatar
I only drive hard when I get on the freeway, because you can shift high on about 4 gears before you are going 80. Rarely will I hit redline, the car is fast enough and I find by 5000 you are going pretty fast and ahead of traffic.
If the guy in the car next to me has a comparable car in speed, and gives a nod, thats another story
Old Mar 14, 2005 | 09:32 AM
GeeWillikers's Avatar
Walking The Fine Line...
Up to and touching should be fine. Manufacturers set redline based on the engine's capabilities. Occasionally revving the engine to redline shouldn't cause any longterm consequences. Daily flogging is another story.
Rev until you see the blue and red warning lights in your rear view, and then back off a bit from that point.
Old Mar 14, 2005 | 02:17 PM
G35keg's Avatar
Even if you hammered it everyday, I would think you would still get 100k miles out of it easily... I wouldn't worry about it and enjoy the car. Why pay $34k if your not going to have fun with it...
Old Mar 14, 2005 | 02:49 PM
azcougarman's Avatar
My philosophy is that God created a redline for a reason, and that's to put the tach needle in it! My car has seen the redline more times than I can count, and don't forget, we do have a revvvvvv limiter!
Old Mar 14, 2005 | 03:14 PM
EG35's Avatar
Excellent advice!
Old Mar 14, 2005 | 03:20 PM
EZZ's Avatar
EZZ
Its probably good to see the redline once in awhile. The old cars needed it to burn off carbon deposits...the new cars probably don't really need to do it but it couldn't hurt.
Old Mar 14, 2005 | 11:14 PM
Nickk6's Avatar
What is the lowest RPM everyone shifts at when driving conservative. I find 2500 RPM is fine to shift at the car does not even struggle to keep up with traffic.
Old Mar 14, 2005 | 11:32 PM
IP05G35's Avatar
You should be able to redline daily with no problems. The 3.5 DOHC is not a pushrod motor, just be sure to use synthetic oil for max upper rpm protection.
Old Mar 15, 2005 | 12:02 AM
G35keg's Avatar
3000-3500 rpms....
Old Mar 15, 2005 | 02:11 AM
doogie's Avatar
When you strap on an AEM cold air intake, your desire for WOT in the upper rev range increases tremendously
You want people you're passing to KNOW you have a powerhouse disguised as a family sedan
If I'm driving with the family in the car or on a sunday cruise I'm shifting at 3.5, maybe 4... kind of hard to make a blanket RPM statement since it truly depends on the situation.
tiguy99
Mar 1, 2016 11:42 AM
03sedang35
Aug 29, 2015 07:56 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
RA081024
Aug 18, 2015 07:03 AM
