Coolant overflowing... but no head gasket leak?
Old Jan 5, 2025 | 09:00 AM
  #31
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
Originally Posted by bmdubya1198
it has gone back down to where it was (max line) except for today.
I wouldn't rely on the max line in the expansion tank. Remove the radiator cap when it's cooled off (at least 30 mins) and if it's not filled to the top you still have air bubbles. I've been adding water/coolant at the radiator cap for months, though less lately since I mostly take short trips (5 miles or less).
Old Jan 5, 2025 | 11:17 AM
  #32
bmdubya1198's Avatar
'07 G35S 6MT
Yeah, a lot of people don't understand that it's just an overflow. That's why I like expansion tank type systems, a lot easier to monitor (and safer if you need to open when hot). Every time I open the radiator cap, it's been full. I'll check today.
That's the tough part with this car, I don't daily drive it or anything. It's a car I'm preparing for sale, and I mostly only drive it on shorter trips. Obviously I try to drive it as much as possible though, since I don't want to sell it until I know for certain that this issue has been sorted out.
Old Jan 15, 2025 | 08:18 PM
  #33
'07 G35S 6MT
Aaaaand this case has finally come to a close! I began tear down to replace a leaking valve cover on the driver side, and in that process I decided to stick a borescope into the lower intake manifold to check for injector leakage. In that process, I peeked into the open intake valves on cylinder 3, and lo and behind, there is some coolant right on the head gasket! Maybe it needed time for the UV dye to circulate and make the leak a little more clear, because I hadn't seen it before and I checked several times on each cylinder.
Not the ideal outcome, but I'm happy to have found solid evidence that this IS in fact a head gasket leak, and that I'm not just crazy and chasing a non-existent external coolant leak.
Thanks everybody who has chimed in to offer help, and best of luck to others who are chasing these issues! Now to decide whether to sell it as is or part it out... because I'm too deep into this car to fix it.
Old Jan 15, 2025 | 10:53 PM
  #34
Urbanengineer's Avatar
Sorry to hear that. I would highly recommend a rebuild if you have the resources but known running engines are getting pretty cheap these days.
Old Jan 16, 2025 | 12:48 AM
  #35
'07 G35S 6MT
Yeah, that’s the hard part for me. I bought this car as a flip last April, and I STILL have it after all this time. The last thing I want to do at this point is a major engine overhaul when I probably won’t be able to pull $3k out of the car once finished (salvage title, mismatched front bumper and crappy paint on the hood… drives well but it’s not perfect). Plus I already have about $2500 into it, so it’s just not feasible. Not counting all my hours of labor and diagnostic time… which I bill at $120/hr to my customers, and apparently I pay myself $0 on my flip cars 😂
Ryan65
Oct 23, 2023 05:39 PM
Ryan65
Oct 23, 2023 09:03 AM
Epidemic
Texas
Jul 22, 2023 10:34 AM
Snailtac
May 20, 2023 10:55 AM
angel246837
Sep 30, 2021 10:39 PM
