2005 G35 RWD Sedan - vibration issue
Old Dec 15, 2025 | 08:44 AM
2005RWDG35's Avatar
Hello, sorry if this is a duplicate post, I tried the search function but did not find anything.
I own a 2005 G35 Sedan RWD (204,xxx KM). I have had the tires balanced (watched the tire technician do it), replaced all rotors and pads, but still the car vibrates at anything above 60 KM/hr. Below 60KM the car is absolutely fine.
Carrier bearing? I visually inspected it and there were no rips but it did seem hollow.
Have anyone else ran into this issue? Any advise much appreciated!
Thanks!
Old Dec 15, 2025 | 10:07 AM
05_SkylineSedan's Avatar
20 Year Member
How old are the shocks or struts?
Old Dec 15, 2025 | 12:33 PM
2005RWDG35's Avatar
Very good chance they are the originals. Should I start there vs worrying about changing the carrier bearing? Should say, the vibration is not felt in the steering wheel.
Thanks!
Old Dec 17, 2025 | 10:11 PM
srv2nv's Avatar
G35 Sport
I had this problem on my last G35. Check your lower control arm bushings. I had no issues at low speeds, but the car felt like it had an unbalanced tire on the highway.
Old Dec 18, 2025 | 12:44 PM
2005RWDG35's Avatar
Control arms ordered, hopefully that does the trick. Will tackle the ball joints at the same time.
Thanks!
Old Dec 20, 2025 | 04:05 PM
MaLPoPieS's Avatar
Jaguar XFR-S
Check your rear drive axles. Once the CV joint wears out, it will wobble and vibrate. Jack up the rear, remove both wheels, reinstall lug nuts on the studs to keep rotors tight and spin the rear to see what makes it shake. It can also be the driveshaft carrier bearing in the middle..
If you don't get any shake with the wheels off, then i'd look into the tires or a different tire shop. Too many tire shops rarely calibrate their wheel balancing machines..
Billimon
Drivetrain
May 15, 2017 07:53 PM
