interior lights
Old Mar 21, 2005 | 03:17 PM
sic35's Avatar
interior lights
forgot to post this as well.. i wanted to change the yellow interior lights.. any help is greatly appreciated..
Old Mar 21, 2005 | 07:14 PM
skeleton_cru's Avatar
Sedan
Your owner's manual should explain how to remove the lenses to access the bulbs. You will need four T6 (8 watt) bulbs. Two for the front map lights and two for the rear dome lights. Personally I used the PIAA Xtreme Whites and I am happy with the results. They are $9.95 a pair here:
http://www.optauto.com/index.htm?par...5&deptid=11983
What year sedan do you have?
Attached Thumbnails interior lights-g35-stock-piaa-front-domes.jpg   interior lights-g35-stock-piaa-rear-domes.jpg
Old Mar 21, 2005 | 07:24 PM
johnzg35's Avatar
I can also vouch for the PIAA Xtreme Whites. Installed them a year ago in my 2003 sedan. Very simple to do.
Old Mar 21, 2005 | 07:53 PM
sic35's Avatar
i have an 03 sedan... i was also looking to change the yellow light in the dash as well.. any info for that? and thanx for the link
Old Mar 21, 2005 | 08:00 PM
Sedan
I'm not sure what light you're referring to. I haven't changed any lights in my dash.
Old Mar 22, 2005 | 08:34 AM
cato's Avatar
SouthernComfort Moderator
He must have ment the glove box lights.
Old Mar 22, 2005 | 09:33 AM
sic35's Avatar
im talking about the yellow lights where all the gauges are, the yellow lights where the radio are and the yellow lights where the tempatures come up
Old Mar 22, 2005 | 09:55 AM
doogie's Avatar
He's talking about changing the dash illumination lights, instrument cluster etc.
He wants a pimp-*** looking blue dash like in the VW/Audis and the Acura TL.
Old Mar 22, 2005 | 10:42 AM
Sedan
Last time I checked those lights were orange, not yellow.
Here is what you're looking for sic35:
https://g35driver.com/forums/g35-coupe-v35-2003-07/25903-my-first-mod-leds.html
https://g35driver.com/forums/g35-coupe-v35-2003-07/35819-more-blue-leds-buttons-56k-maybe.html
https://g35driver.com/forums/lighting/36787-led-project-part-3-gauges-revealed-56k-haha.html
https://g35driver.com/forums/lighting/39381-stage-4-done-blue-ac-compass-temp-display.html
You can thank me for searching for you later.
Old Mar 22, 2005 | 11:38 AM
sickpig's Avatar
Have fun! Somebody on here has done it but it looked extremely time consuming and tedious. Looked amazing but involved chaging out DOZENS of LED's. Not a simple job at all. I'll keep my orange dash.
Mark
Old Mar 22, 2005 | 11:52 AM
Sedan
Mark
accordfreak did it to his coupe. It is hours and hours of work, but the result is pretty amazing.
Old Mar 22, 2005 | 12:42 PM
sic35's Avatar
https://g35driver.com/forums/showthread.php?t=25903
https://g35driver.com/forums/showthread.php?t=35819
https://g35driver.com/forums/showthread.php?t=36787
https://g35driver.com/forums/showthread.php?t=39381
thankyou
Old Mar 22, 2005 | 01:27 PM
aluislugo's Avatar
Interior Lights
The kit that I bought, I believe has 8 lights. One was for the trunk, which was different shape. The other seven I am not so sure about and it did not come with directions
Anyway I think that two are for the map lights and the other two are for the vanity mirrors. And maybe one right above the foot rest. After that it's anybody's guess. Any ideas? Also, how to gain access to those different locations would be greatly appreciated.
Old Mar 25, 2005 | 11:00 PM
Sedan
(2) HIGH BEAM/FOG HALOGEN (60/55W) HB2, 9003, H-4
(2) HID HEADLIGHT EXTERIOR HID XENON D2R
(2) CLEARANCE WEDGE (5W) T10 (168)
(2) REVERSE WEDGE (18W) T16 (W2)
(1) LICENSE PLATE WEDGE (5W) T10 (168)
(2) STEP LIGHTS (UNDER DOORS) DOME (5W) T6
(2) SPOT LIGHTS (FRONT DOMES) DOME (8W) T6
(2) REAR PERSONAL (REAR DOMES) DOME (8W) T6
(1) TRUNK LIGHT WEDGE (3.4W) 158 (168)
(2) SIDE MARKER WEDGE (5W) T10 (168)
(1) TOP GLOVE BOX WEDGE (5W) T10 (168)
(1) BOTTOM GLOVE BOX Unknown
You can find the instructions on how to access most of the bulbs in your owner's manual. Take the time to read it front to back, you'll be surprised the things you'll learn.
Old Mar 27, 2005 | 06:36 PM
sweetdaddy's Avatar
This is bit off the subject, but I have a question that maybe someone out there can answer. Are the buttons in the mirror for the home link and auto dimming feature lighted when the headlights are on? I just picked up my 05 G35 and they do not light up when the headlights are on.
Thanks
