Battery Disconnect
Old May 17, 2003 | 10:16 AM
SixFive's Avatar
Battery Disconnect
When resetting the computers to regain mod performance and tranny reset....Is there a fuse that can be popped out that cuts power to the computers involved? Also could a inboard switch work for cutting battery connection?
Can't believe my car outsmarts me and I have to fung with it like this to make the mods work..
Old May 18, 2003 | 10:20 AM
1Ken's Avatar
Re: Battery Disconnect
It takes me no more than 5 minutes to take off the battery cover and disconnect the negative battery terminal. For me, that has been no great inconvenience. This is about as easy as anything I've done with the car. Ken
Old May 18, 2003 | 02:22 PM
Msedanman's Avatar
O.F. Administrator
What you need is a main battery disconnect, like you'd find on big rigs. Shouldn't be too hard or expensive to wire in.
<font color=green>GSM</font color=green>
Old May 24, 2003 | 05:20 PM
911toG35's Avatar
what is the purpose of disconnecting and reconnecting the battery?
Old May 24, 2003 | 05:32 PM
Merlin's Avatar
Staff ALUMNI
Basically it resets the computer from the driving patterns it learned/stored since the last disconnect. Affects the throttle response and transmission shifts patterns.
Depending on the driver it does make a seat of the pants impression. Try it you may like it.[img]/w3timages/icons/smile.gif[/img] Disconnect for at least 3-12 hours.
Old May 25, 2003 | 06:24 AM
Timsmith's Avatar
Hi,
What about the 6mt? Does it effect the engine in the same manner?
Old May 25, 2003 | 09:28 AM
Msedanman's Avatar
O.F. Administrator
It's thought that it may have a positive effect on throttle response and other things on 6M/T's also. We're waiting on some feedback to confirm this. Give it a try and post with your results..........[img]/w3timages/icons/smile.gif[/img]
Old May 25, 2003 | 08:07 PM
Timsmith's Avatar
Hi,
I will, what if any care must be taken?
Thanks
Old May 26, 2003 | 12:35 PM
Merlin's Avatar
Staff ALUMNI
Disconnect the Negative terminal not the Positive, less sparks when reconnecting and generally safer. Keep us posted.
Old May 26, 2003 | 07:11 PM
pestilence's Avatar
Has anyone heard of a button to disable the starter? Sorta like a starter kill switch.. but instead of having to type in a code.. just flip a switch?
The reason I ask is beucase my G was displayed at Hot Import nights this past weekend at the Long Beach Convention center and they requrid the battery to be disconnected (or a starter kill switch) to basiclly prevent your car from being started while there are people in the showroom..
My plan is to intstall a starter kill switch in the glove compartment so I can disblae the starter, however keep my key in the car so I can power my LEDs, system, and soon to come neon lights :/
Old May 27, 2003 | 06:35 AM
Timsmith's Avatar
Thanks I will try this.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
happydays888888
Oct 6, 2015 06:04 PM
dcsbh1
Oct 1, 2015 03:15 PM
