repaint piece or touch up?
Ok so I bought a G35 and they found a paint chip on it...they want to know if i want the piece repainted or touched up.
They said if its touched up you would still probably see a blimish.
But someone told me a repainted panel doesn't hold up as well and chips even easier.
Whats do you guys think?
the repainted panel may chip easier but i doubt it. Alot of it has to do with the quality of paint used, and what tempurature it is painted at and if it is baked or not, i would probably have the piece repainted because youll see the repaired spot very easily. I would tell them that you want it blended. Blending is where you paint over only the spot that it chiped at and reclearcoat the whole surface.
Blended Paint Job
I had a chip and scratch in my Emerald Mist (metallic green) sedan, and had the 'blended' repair performed just because I was concerned that no one could really match the factory paint job. I was really concerned, but all turned out well.
Maybe teh key is to use a really good pro shop who has done this a lot before?
i did take delivery, but it was at night and there was alot i couldn't see, and i was way too excited. It was also too late for them to do the final detail so they told me to come back when it wasn't raining. A few days later when i did come back, i showed them a scratch and the chip. And they said they would take care of it, no problem.
The chip was on the back quarter panel...which, my guess is they can't remove, because i think its welded to the frame...i'm not sure though. Its a huge section of the car. I ended up teling them to repaint the area. Hopefully it comes back great. We shall see
