Need alignment for 04 Z suspension??
Old Mar 31, 2005 | 07:56 AM
Harlem2k's Avatar
oh btw, speaking oh H-tech..
IMO the oem z spring drops enuf of the car already. H-tech probably drops an other .5-.7 inch if i remember correctly... which will give you about almost 2 inch drop in the back.. in that case.. i think u'll definately need camber kits to go with it... which will make your wallet go even thinner
given the road conditions here in Greater Van... I don't think i'll want to drop my G more then what the oem 350z give me.. but that's just me
Old Mar 31, 2005 | 09:35 AM
roro's Avatar
what is the drop on a Z D-Spec (DSP-9) / 04 Z spring setup?
Old Mar 31, 2005 | 11:39 AM
dklau33's Avatar
Should be 1 inch.
Old Mar 31, 2005 | 11:45 AM
dklau33's Avatar
Nope, the H-techs for the 350Z drop the 350Z -0.3/-0.2 front and rear according to the specs on their website. So figure a -1.3/-1.2 drop on a sedan.
Old Mar 31, 2005 | 06:18 PM
Harlem2k's Avatar
i see
I thought it was more then that
thx for correcting
Old Mar 31, 2005 | 11:39 PM
Renesis's Avatar
Yeah, I think I will either go with OEM Z springs or H-techs if I can stay clear from the fender. I should be buyign some wheels soon also.
Old Apr 1, 2005 | 02:28 AM
dklau33's Avatar
i see
thx for correcting
No problem. I think you were thinking of the S Techs for the sedan which drops -2/-1.3 according to the website.
Old Apr 1, 2005 | 04:06 AM
Renesis's Avatar
Renesis, I recently put on a set of 03 350z suspension I got off from Jim (thanks Gsedan35) and I think you will find the ride to be very harsh for roads here in VanCity..
I never tried the 04 revised version... so i can't compare the two.. but I think for me, I'll definately want some D-Spec in the future to go with my 03 350z springs.
are your 04 suspension assembled already? I mean is the front still intact with the spring mounted and all?
since you got it already why not just install them and see how you like them? Might take you a while to install but once you get a hang of it, it's very easy to do.
I just installed mine last weekend with my buddy... it was a little tough at first, but after we did the first front side and frist back side, the 2nd time around was really fast and easy to do.
I really want to try some 04 350z springs to see how different it'll feel.. I orignally wanted the 04s like you but I just can't find any around here... so I went with the 03s, and I was prepared for a very stiffen ride...
After I got it on and now i've driven for over 4 days through Roards in vancouver, Burnaby and Richmond... I am finally getting used to feeling the little bumps and humps on the road surfaces now I think it might take me a while to totally get used to it since I'm coming from non-sport suspension and now to the 03 350z suspension... but I can tell you that all the advertised results from previous threads on how the G handles with the 350z springs are absolutely true.
and what Jim have posted over and over again is very true as well. Weight transfer is night and day better, roll issue is pretty much gone in corners.
if you are serious about getting rid of your 04s.. pm me a price... I'm really kinda interested to see how different they are.. but ultimately... I think... one should really look for the D-Specs shocks. The firmer setting on the shocks should help out the ride issue quite a bit..
just me 2 cents..
Interesting Harlem, I live in Vancouver as well. I never seen you in the meets before, maybe you gotta participate.
Old Apr 1, 2005 | 04:12 PM
Renesis's Avatar
are you interested Harlem??
Old Apr 2, 2005 | 01:29 AM
Harlem2k's Avatar
it's a little expensive acutally. If that's the going price for them on the net, I think I'd settle for 03 springs with D-spec
Old Apr 2, 2005 | 05:36 AM
Hyde's Avatar
i find the 350Z suspension gets scary when the road gets bumpy
its still controllable and its great on the track.
but i dont see how i can go with shocks and stock springs... i might as well get coils like TEIN basic.
i guess u dont want harsness.... i find the 350Z still very suitable for the roads in Van. no where near coilover harsness
Old Apr 6, 2005 | 03:02 PM
Renesis's Avatar
Originally Posted by Gsedan35
With oem Z springs get the DSP-9's (350Z version).
Is the spring rate for 03 and the revised ones the same?? I think I remember Gsedan35 said long time ago that only the shocks are valved differently, the spring rates are the same for both. Is it possible to sell the shocks to a 03 owner and it would still ride like the new one?
Old Apr 6, 2005 | 04:12 PM
Gsedan35's Avatar
Your really not understanding the dynamics of things. The shocks reason for existance is to control the spring, don't blame the springs for something that is the shocks fault. You will see a night and day improvement with the right shock on the car. I've driven in 2 sedan's with D-specs, vastly superior to ANY oem shock put in any G or Z and in both cases the shocks could have been set softer if the owners wanted to. The only reason to do different springs would be because you want a different drop or you want to have a softer then oem G35 ride quality.
Old Apr 6, 2005 | 04:19 PM
Renesis's Avatar
hehe.............. any ideas on the difference in spring rates then, Gsedan35??
Old Apr 6, 2005 | 04:25 PM
  #30
Gsedan35's Avatar
Their remains a unconfirmed rumor that the rear spring rates for the revised 04 350Z suspension (05 Z's would have the revision as well) are higher, 417lbs is what I was actually told. But it sounded like second hand info. However, I have new info that places the rear spring rates on the new 05 G35 coupe sport suspension at 427lbs, that makes the thought of the revised Z suspenison going to 417lbs in the rear more believable to me. Which would also explain why I've seen reports about the front sway bars on revised 04 Z's weighing more then 03 front bars, thicker walls for a slignt bump in stiffness.
