Hey guys - need measurement help
Old Apr 6, 2005 | 12:46 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Question Hey guys - need measurement help
I'm doing some suspension testing with different springs on my sedan.
& will post up some data in the "MODS" section when finished
Since I don't have my OEMs on any more.......
I would appreciate if someone would take some base line measurements
of both a basic & a sport suspension sedan. (front & back)
To avoid tire/wheel differences, inflation etc.
please measure from the top of the fender wheel arch
to
the center of the wheel hub.
#s should be in the +- 15" range
Thanks
any help appreciated
Old Apr 6, 2005 | 01:25 PM
Gsedan35's Avatar
Why not go by what the FSM tells you oem ride height is and simply use that as your baseline against what you measure? IIRC it does not show a ride height differance between sport and non sport sedans.
Curious, what springs are in your test pool?
Old Apr 6, 2005 | 01:43 PM
InTgr8r's Avatar
I'm not on stock wheels & rubber.
Just though I'd eliminated measurment variances due tire sizes, inflation etc.
The measurment to hub center should be constant no matter what tire & wheel package.
(data whould then apply to anyones setup)
Eiback PRO & 350Z OEMs currently in pool plus whatever else I can scare up.
Testing with stock sport shocks & D-specs
Cajuncowboy
Jun 21, 2021 09:47 AM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
Footballmania32
19 Inch
Aug 13, 2015 03:07 PM
underworld
Aug 6, 2015 01:36 PM
Frostbite91
Jul 27, 2015 05:25 AM
