Scraped the underneath of the front bumper
Old Apr 19, 2005 | 12:09 PM
dirrtybear's Avatar
raises all-in
I ran into the damn concrete barrier in front of the parking space (why do they have to place these things in the first place?) and scraped the plastic piece (wind deflector?) underneath the front bumper pretty badly.
Old Apr 19, 2005 | 12:16 PM
GeeWillikers's Avatar
Walking The Fine Line...
How bad? How much of the diffuser did you clip?
I park way back from the curb since I got my G. The first time I parked it like I used to park my Maxima. I got out and looked and if I had gone about three inches further into the spot I would have taken off about the bottom 1.5 inches.
Did you do any real damage, or is it just cosmetic?
Old Apr 19, 2005 | 02:04 PM
dirrtybear's Avatar
raises all-in
It looks to be just cosmetic. It basically shaved off a quarter inch or so on the right side of it.
Old Apr 19, 2005 | 02:08 PM
Msedanman's Avatar
O.F. Administrator
They're not expensive to replace. If it's bad enough, just order another one.
C.
Old Apr 19, 2005 | 11:45 PM
2005G35x's Avatar
I did the same thing to my G!. I was meeting some friends at a restaurant when I drove myself and then parked the car. When I left, 3 friends joined me in the car. What I didn't know was that the bottom lip of the front bumper just clear the concrete barrier barely when only the driver was in the car. Add 3 other adults, the increase weight lower the whole car and when I backe out the spot....you know the story.
That piece is only a plastic and you have to knee down in order to see the scratches. I guess just get some touch up paint and cover it up since hardly anyone will notice except you.
Old Apr 19, 2005 | 11:54 PM
Jp1's Avatar
Jp1
2005g35x
He's right.
Old Apr 20, 2005 | 12:21 AM
ABQ_G35's Avatar
C.
Colin, is the black front valence on the '04 replaceable too, or does the entire bumper cover need to be replaced?
Old Apr 20, 2005 | 08:38 AM
If it's just cosmetic and nothing is actually broken I'd leave it go - above said it correctly - no one will know it but you.
Old Apr 20, 2005 | 08:39 AM
Pics?
(I never pass up an opportunity to see pics. lol)
Old Apr 20, 2005 | 10:45 AM
socketz's Avatar
The black portion along the bottom is about $300.
I did something similar, looked into buying one, but then decided to repair it myself.
I basically took some 600 grit wet sandpaper and sanded the scrapes down, then used polish to buff out the scratches (slight ones) from the sanding. Looks almost new.
Old Apr 20, 2005 | 12:03 PM
ABQ_G35's Avatar
How big were those scrapes? I have one I'd like to remove.
Old Apr 20, 2005 | 12:17 PM
townsley's Avatar
I've done this a handful of times myself. Each time, I use a razor blade to shave off the frayed plastic, then some fine sandpaper to smooth it down. You can really make it look new again with a little work.
Old Apr 20, 2005 | 07:37 PM
RxCritical's Avatar
Been there, done that! Actually my wife did it first, then I did it. It suxs, but it's not noticable so I haven't touched it and don't plan on touching it.
Old Apr 21, 2005 | 10:15 AM
socketz's Avatar
"How big were those scrapes? I have one I'd like to remove."
Mine were a pretty decent size (6 inches or so). I was down by the beach and tried parking in one of those little back ally lots that had a busted up cement wall at the tight little entrance. I wasn't able to swing the car into the entrance correctly and scraped the driver-side corner of the lip spoiler over the top of the jagged cement.
It was noticeable for sure. I thought about buying one, but thought I'd give the razor/sandpaper approach a try. The plastic is pretty soft, so it's pretty easy to 'sculpt' the plastic so that you can hardly see the scrape. Then, polish out the bigger scratches and hit the whole thing with a little Armor-All to blend (i.e the sanded part ends up looking alot cleaner than the original portion).
Tukeeg35
Sep 27, 2015 12:16 AM
derres
Aug 28, 2015 03:27 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
st33zygill
Jul 29, 2015 10:05 PM
