Nismo S-Tune
Old Apr 22, 2005 | 02:35 PM
kei's Avatar
kei
Nismo S-Tune
Hello, does anyone have the Nismo S-Tune and/or R-Tune suspension setup on the G35 2005? I would appreciate any feedback on the rides with these setups and where they were purchased. Thanks!
Old Apr 22, 2005 | 04:07 PM
Gsedan35's Avatar
Nismo offer's a JDM S-tune suspension for the G35 sedan. However, it does not use specs that are cause to whip out the ole credit card. Frankly, it's all too easy to do the same thing, even adding the ability to adjustable dampning and no progressive springs for a whole lot LESS money. Tokico D-spec shocks and oem 350Z springs, 1" drop.
Using the 350Z/G35 coupe S-tune on the sedan is a whole different matter, 1.6" drop and allot more aggresive spring rates and dampning, but still no ability to adjust dampning and progressive springs.
Nismo S-tune (twin tube construction, uses progressive springs, especially in rear)
350Z/G35 Coupe
Spring rates 448/504
Stiffer then oem by F+43% R+48%
Transfers +5% roll stiffness to rear
Nismo S-tune (twin tube construction, uses progressive springs, )
G35 Sedan 1.1" drop
Spring rates 347/342
Stiffer then oem by F+10% R+0%
Transfers 10% roll stiffness to front
Old Apr 25, 2005 | 01:48 AM
kei's Avatar
kei
Thanks for reply. I'm thinking about the Nismo S-Tune or the Tein CS but just wanted some thoughts on the S-Tune.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
