Sport Bumper & PIAA Sportmesh Installed - PICS
Old Apr 28, 2005 | 12:16 PM
  #31
blackonblackG's Avatar
Are your springs from a 03Z or 04Z. Also if you were using the Z shocks prior to the D-Spec shocks could you comment on which rides better in terms of comfort and handling. I am running full 03Z suspension with 245/45 18 and I am definitely going to change to what you have next time (245/40), since in the back my wheel gap is sometimes 1 finger or less. Your setup looks good. I am thinking about getting the Dspecs with my 03 springs and if the ride isn’t good I might change to 04 springs.
Old Apr 28, 2005 | 12:35 PM
  #32
callmecarlito's Avatar
Originally Posted by SnMDesignStudio
Classy, aggressive, and clean. Great balance between a mean stance and appearance and a classy, luxurious look. Excellent.
could not have said it better myself.
Old Apr 28, 2005 | 12:49 PM
  #33
InTgr8r's Avatar
Staff ALUMNI (retired)
I have '05 springs.
I don't think it makes any difference though.
The D-Specs will make a dramatic change!!!!
The mid'04 change on the Z was shocks only. '03 & '04 springs are the same rates, (info from Gsedan35)
I was running Eibach Pros c/w sport suspension shocks b4 the change.
I installed Z springs & D-Specs at the same time along with 350Evo rear sway.
Old Apr 28, 2005 | 01:36 PM
  #34
Gsedan35's Avatar
That has changed a bit. Rumor is that the revised Z suspension changed the rear spring rates from 342 to 417. Attempts by me to get anyone to send me a single rear spring to confirm or deny this rumor have thus far failed. Giving the rumor a boost in my mind is the fact that due to the considerate help of a member here, I was sent a single front and rear spring off of a 2005 coupe sport suspension to get the spring rates off of. Front rate was the same (314), rear rate however is 427(vs 342). Also of note is the fact that the rear shocks on the 05 coupe sport suspension are the same shocks used on the revised 350Z suspenison. However, until I get a rear spring in my hands from a revised 350Z suspension, we won't know if the rumor is true or not. All I need to do is test it and I'll return it within 48 hours.
Old Apr 28, 2005 | 01:48 PM
  #35
InTgr8r's Avatar
Thanks for the clarification.......
It's too bad I wasn't closer (& on the south side of the 49th), I could have swapped the Eibachs back in temporarily for you to test the '05s I have.
Is there any way I can duplicate your test method???
Old Apr 28, 2005 | 01:59 PM
  #36
Gsedan35's Avatar
Spring has to be off the car. Then multiple dial caliper measurement's are needed, especially of the wire diameter. Really helps if the caliper can show .57" type readings
1. Number of active coils (should have 4 if I recall)
2. Outside diameter of the coils (should be 5")
3. Multiple wire diameter checks, getting this right is critical as even small changes will effect the rates.
Old Apr 28, 2005 | 02:14 PM
  #37
InTgr8r's Avatar
I'll see what I can do....
I think I have a source to access a dial caliper.
(may take a week)
FWIW
Heres a pic of the '05 Z spring......
Left is OEM sport, middle = Z, right=Eibach
Old Jun 1, 2005 | 09:18 AM
  #38
jeffy1's Avatar
Nice ride. I noticed that your location is Toronto.
I recently bought a 2005 Silverstone 6MT sedan with graphite interior and would like to have it tinted 35% all around. Can you tell me where in Toronto did you have your tinting done? I would prefer to have it tinted at a place where the tinters have experience tinting G's. Any recommendation would be appreciated.
Old Jun 1, 2005 | 10:31 AM
  #39
InTgr8r's Avatar
Welcome aboard jeffy1...
Be sure to check out the Canadian section forum, there's
lots of info there.
Also lots going on in the GTA with meets etc.
Here's a link to tints in GTA
https://g35driver.com/forums/canada/48199-excellent-tint-shop-toronto.html
Old Jun 1, 2005 | 10:53 AM
  #40
SGT's Avatar
SGT
Thumbs up
Very nice job on the car. It looks HOT.
Old Jun 1, 2005 | 12:28 PM
  #41
badtz's Avatar
Looks great! i was told that the 18x8.5" only come in black for the Piaa sport mesh. Where did you get those and was it super special order?
thanks
mark
Old Jun 1, 2005 | 12:41 PM
  #42
InTgr8r's Avatar
thanks
mark
Thanks Mark, they are "hyperblack", which is the standard color.
They are painted black on the back side of the rim.
The front is more of a dark silver look.
The finish is really great.
I'm in Canada so my source wouldn't work for you,
but if you Google PIAA Sportmesh you'll find a few places.
Old Jun 1, 2005 | 01:13 PM
  #43
badtz's Avatar
So that's their hyperblack? you photos look as if they are straight up silver! does it look like the color in your posted photos in real life? or is some strange photographic/lighting phenomena making it look silver in your pictures.
Old Jun 1, 2005 | 03:02 PM
  #44
InTgr8r's Avatar
Yup pics are pretty close to real life.
It was a dull day so no exaggerated over exposure from the sun.
I'd say they're more of a dark silver as opposed to brilliant silver.
Old Jun 1, 2005 | 08:42 PM
  #45
G35Lin's Avatar
Multi-Spoked Mod
kinda high.... ;P
anyways.. nice car...
Ed lin
