Final test drive - two observations
Old Apr 27, 2005 | 11:18 AM
DingoNY's Avatar
1) I can't find the way to adjust the "adjustable lunbar support"? I checked all sides of the seat, and seat back. What am I missing?
2) The auto-on/off headlights do not turn on when you turn on your wipers. (Do other manufactures do that automatically?)
Old Apr 27, 2005 | 11:37 AM
G'nJag's Avatar
The lumbar support is located between the driver's seat and the pop up console, kinda tough to find as it is only a small lever molded to match seat color. It's kind of tough to work with, but not horrible.
I don't use the auto headlights, so can't help ya there.
-Enjoy!
Old Apr 27, 2005 | 11:40 AM
G35_coupe_6MT's Avatar
1) It should be on the side of the drivers seat
2) I always use Auto on/off headlights and there have been times when I used the wipers while lights were on.
Old Apr 27, 2005 | 11:49 AM
DingoNY's Avatar
1) I had thought it was on the other side of the drivers seat (window side) so I spent more time looking there, and took only a quick glance on the other side. I was puzzled. Is it on the base of the seat or on the seat back?
2) I imagine there have been times when you used the wipers and the lights were on - because it was "dark enough" out for the auto headlights to come on. In NY - if we have wipers on, our headlights need to be on. Not a huge deal - just a tiny detail I feel they "missed". Then again, I'd kind of like daytime running lights too
PotomacG's Avatar
Originally Posted by DingoNY
...The auto-on/off headlights do not turn on when you turn on your wipers...
As designed. The two systems are not connected.
Old Apr 27, 2005 | 11:50 AM
calejohnson's Avatar
Correct. I don't know about other cars but I find it a little annoying that the lights don't turn off when in the manual "on" setting and the car is turned off. My Subaru does that and it's just makes sense to me.
Old Apr 27, 2005 | 01:01 PM
dirrtybear's Avatar
raises all-in
Huh? I'm confused. You agreed with him, then you say the two systems are not connected.
Old Apr 27, 2005 | 02:17 PM
doogie's Avatar
They do... eventually. I think it takes like 45 seconds after locking the car or something.
Old Apr 27, 2005 | 03:24 PM
Homeslice's Avatar
That is in auto mode. I think in the "on" position the lights stay on for 5 minutes after the car is turned off and you exit.
Battery save feature.
Old Apr 27, 2005 | 03:43 PM
Oh, that's interesting. I've never left them on to see that happen.
Old Apr 27, 2005 | 04:32 PM
SaltiDawg's Avatar
2) ... In NY - if we have wipers on, our headlights need to be on. Not a huge deal - just a tiny detail I feel they "missed". Then again, I'd kind of like daytime running lights too
In the Canadian version you'll find both features. To accomodate the daytime running lights they put the two high bulbs in series (1/4 power) and I believe that requires the HID bulbs be replaced with Halogen. (Maybe a Canadian owner can confirm.)
I also would like the headlights to come on automatically when wipers are operated as this is the law here in Maryland also.
Old Apr 27, 2005 | 04:47 PM
Andy77's Avatar
I've never had a car with lights that come on with the wipers. If you just want a short wipe you wouldn't want the lights to come on, especially since the manual says that the life of the xenons "will be shortened by frequent on-off operation."
The headlights will turn off automatically after 5 minutes if in the "on" position. The manual (p2-21) refers to this as a "battery saver" and does not recommend leaving the switch in the on position for long periods when the car is not running. I am not sure why it is a problem, but I follow that particular one.
The lumbar control is on the side of the driver's seat near the console.
The manual is available on line for downloading-I'll find the site.
I thought you were ready to buy it already!
Old Apr 27, 2005 | 04:57 PM
Andy77's Avatar
Here is the link to download the owner's manual. I downloaded the one for my 04 in Sept 04 about a month before I was even serious about buying it and curiously, the 05 manual was there also, months before the car was released.
http://www.nissan-techinfo.com/infin...p?dept%5Fid=56
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
GBoy
The Q - Spot
Sep 5, 2015 03:15 AM
NemesisGee
Aug 11, 2015 07:10 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
