When to change to synthetic?
Old May 4, 2005 | 09:42 PM
seattleG's Avatar
Hello every one, our G sedan has 20,000 miles on it and it is due for its oil change at around 22,000 miles. I was woundering, would it be alrite to switch over to Mobile 1 synthetic or is it to late? Would it void the warrenty? And what weight and filter do you recomend?
Thanks you all
Old May 4, 2005 | 10:02 PM
G35_coupe_6MT's Avatar
I read (in this forum) that after 20k miles its safe to change to Synthetic so you are right on the spot... but wait for others to confirm this.
Old May 4, 2005 | 11:33 PM
redz06's Avatar
mileage to change oils
7500 miles is all right.
Breakin is at 10K
Currently at 25K.
Old May 4, 2005 | 11:49 PM
redz06's Avatar
Change to Mobil One
I should clarify that with the "old" formulation of Mobil One, a switch to this oil at 20000 miles caused substantial rear main seal leakage of my 944 Turbo engine. I would still make this change again as I was trying to increase the reliability of the turbocharger oiling system vs dino oil. My preference, based on experience, would be to change earlier. I changed over my G35 at 7500 miles, and my Corvette Z06 came from the factory with Mobil One oil.
Old May 5, 2005 | 01:36 AM
WRX2G35's Avatar
Former G35 Driver
With my Volvo V70 T5 I changed to Mobil 1 synthetic oil at the first oil change
at 5000 miles. I changed oil every 5000 miles, sold it with 95K miles without
any engine oil problems.
I might change to synthetic at my 7500 mile service.
Old May 5, 2005 | 01:56 AM
imnohero's Avatar
Doesn't the owner's manual say to use mineral oil?
Old May 5, 2005 | 06:46 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Isn't "mineral oi"l used for an upset tummy?? You coulda' changed to Syn. 20,000 miles ago via your first oil change. I've been using Syn. for over 15 years...EXCLUSIVELY. That means in my fleet of 6 tractor trailers, all my motorcycles, and in all my cars. I always switched over at my first oil change. Not good enough....? How 'bout Corvettes and Vipers comming in with Mobil ! already installed? How 'bout most all high end Euro cars as well??? Do it. The US military has for about 30 years as well.
Old May 5, 2005 | 08:04 AM
spendgy's Avatar
Dino vs Synthetic seems to come up all the time on this board.
Bottom line, do whatever you feel comfortable with. It is perfectly safe to change it out at mile 1. Like mentioned above, there are vehicles coming from the factory with synthetic already installed.
I've sent samples of my oil out at 6 month intervals for most of my cars and I can tell you that changing to synthetic has had no ill effects as some might want you to believe. Send your oil to Blackstone Labs and have it analyzed after ~3500 miles with synthetic and see for yourself.
Old May 5, 2005 | 09:51 AM
Is there any other reason to use synthetic other than to have the oilchange be done after longer periods of time? If there is no other "improovement" I dont mind doing the oilchanges every 3k miles.
Old May 5, 2005 | 10:12 AM
imnohero's Avatar
This is bad advice. The arguement of synth v. "dino" oil has been going on for a long time. But the bottom line is the owners manual says to use mineral based oil...if your worried about your warranty coverage, call Infiniti before you switch.
Old May 5, 2005 | 10:21 AM
G3NIU5's Avatar
regular oil on my G for 20K miles now. change my oil every 3-4K. did this w/ a previous car no problem. did synthetic too early on on another car before no problem. benefits? longer oil change intervals only on synthetic. same engine life expectancy, both reached 150K miles solidly before i sold them.
Old May 5, 2005 | 10:22 AM
Wingsprint's Avatar
Here we go again!
There is no reason to break-in an engine on non-synthetic oil. Porsche has been using synthetic as their factory fill for years.
My company builds racing engines and we have found that using synthetic oil while breaking-in a new engine actually improves the break-in process. Bearings, cams, piston rings, and cylinder walls have consistently been in better condition after break-in using synthetic oil. The break-in process is a time of great stress on an engine, especially during start up. better and more consistent lubrication is critical.
As far as synthetics causing seal and gasket leak problems, TOTAL CRAP! Seals and gaskets ether leak or they don't. It does not matter what kind of oil you are using. Period.
Old May 5, 2005 | 11:17 AM
spendgy's Avatar
Sorry, but your reasoning is way off. Infiniti cannot deny you warranty services simply because you've changed your oil to a synthetic. They would have the burden of proof to show that changing to a synthetic somehow was the cause of failure for any malfunctions that occurred.
You do realize that some Infiniti service stations offer the option of putting in synthetic don't you?
Old May 5, 2005 | 11:33 AM
imnohero's Avatar
How is my reasoning off by suggesting seattleG contact Infiniti to get a defintive answer?
"Infiniti cannot deny you warranty services simply because you've changed your oil to a synthetic."
It's nice to know we have an official Infiniti rep on the board. >8|
Old May 5, 2005 | 12:52 PM
G35sedanman's Avatar
As far as I know, as long as the oil meets or exceeds the API performance rating that is required in the owners manual, your warranty is protected if you can prove oil change intervals, oil/filter type.
