Rubbing Issue?
Rubbing Issue?
I have 20 inch rims with a 35mm offset on my G35 sedan NON sport suspension, if I lower with Eibach Pro Kit or 350Z springs will it rub?
They are 20 x 8.5 and the tires are 245/35/20 all around and this is on a regular sedan suspension
If you do rub it will be on the small inner fender lip. This can be successfully rolled or cut to aleviate the problem.
yosip1115
Aug 20, 2015 10:30 PM
