Opinions on offset for 03 G35 Coupe
Old Jul 26, 2015 | 03:23 AM
Popes's Avatar
I'm wanting to buy some wheels for my G, I'm think 19x9.5 +10 245/35/19 front and 19x10.5 +15 275/35/15 those seems to be common tire sizes? Does have Brembo brakes, will I have any rubbing issues? I'm sure I will need to roll my fenders. I currently have Tei H-Techs and will end up buying BC coilovers
The wheels are Work CR2P
Old Jul 26, 2015 | 10:09 AM
gary c's Avatar
Tire size is perfect for a coupe. Offsets are a way low unless you're doing that off the wall camber thing /-0-\ where you're buying tires ever 5K miles. Offsets s/b in the low 20s so you won't need spacers and you can run the tire size you posted...Gary
Old Jul 26, 2015 | 02:52 PM
Popes's Avatar
So maybe +20 offset in the front and +20 in the rear? The look I'm going for is as close to the fender edge with minimal fender rolling
Old Jul 29, 2015 | 05:07 PM
driftsucky's Avatar
Listen to Gary. You ain't built for the flushness. It'll look good and you won't rub. There's no such thing as "minimal" fender work. You're either rolling, pulling, or replacing.
TWASkyliner
Feb 8, 2020 08:00 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
