Accord V6 Coupe Faster at 80 to 100 mph?
Old May 27, 2005 | 02:06 PM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Should of Dropped to 4th and TAPPED that ARS!!!!!!!
Old May 27, 2005 | 02:49 PM
EX-250's Avatar
You can get 88 mph out of 3rd at 6500 rpms. Thats still 10+ Mph out of a gear... 4th MIGHT have worked... but you would have stayed even until you hit about 85 in 4th. Going to 3rd (while it requires you to do a little more work) would have given you the most of your car. Whoever said just going 3rd for that short wouldnt work.... you stay in 4th, ill take the 10-15MPH out of third... it doesnt seem like much, but thats atleast an extra hood length to the car in third.
Old May 27, 2005 | 03:33 PM
dbarnes's Avatar
Originally Posted by ashadiow
6th is an overdrive gear, pretty much useless, so 5th can be considered your top gear. 4th should run from about 90 - what, 110/115 or so, 3rd from 60 - 90, you should dropped to 3rd, slammed it into 4th as you are passing him and waved good bye.
Actually, 5th & 6th are both overdriven. 3rd is good to 90 MPH, but it's a pretty violent downshift at 75 MPH. Still - if you wanted the "slingshot" effect, 3rd will get you there, and you'll shoot by him if you upshift to 4th cleanly.
Nonetheless, I did almost exactly what you did, out of anger, with an Acura Integra GSR "riced out" with big wing, etc. - and if he'd had nitrous or forced induction, he'd have eaten my lunch. I just got on it in 4th (at about 3500 RPM's), took forever to even begin pulling alongside, and finally went by him at about 125 MPH in 5th, grabbed 6th and let him know I had more for him, but still felt like an idiot for two things #1) Not shifting properly and embarrasing myself and the "G", and #2) doing something that stupid to begin with.
I deserved to be embarrassed, and try to use that as my motivator to not get into such "tussles" in the future (although my willpower is still too weak to be certain it won't happen again).
Old May 27, 2005 | 03:41 PM
Msedanman's Avatar
O.F. Administrator
You let him off this time. Next time gear down more, 4th or even 3rd. Should have no problem.
And you're right about tailgaiting...That's asking for trouble.
C.
Old May 27, 2005 | 06:38 PM
dpinto1's Avatar
5 At
Would you be able to double tap from 5th to 3rd in an auto trans? Or would you be forced to go into 4rth by the ecu?
Old May 27, 2005 | 07:21 PM
heeb's Avatar
^You'd be better off just throwing it into straight up D
I used to use manumatic to downshift to quickly shift lanes in a tight squeeze, but its so much easier to just slam on the gas, let the car downshift for me, and then by the time I switch lanes the car takes off.
Old May 27, 2005 | 11:41 PM
EX-250's Avatar
Again... 5th is not an overdrive in the G35... its 1:1 ratio.... NOT over drive
Our only overdrive gear is 6th.
Old May 28, 2005 | 01:51 AM
Klubbheads's Avatar
On a stock G 3rd goes up to 82-83 thats taking to 6900rpm.
Old May 28, 2005 | 02:39 PM
pfizzle's Avatar
Originally Posted by DaveB
Ummmm....the 6MT Accord coupes have been tested by the mags as getting 14.3-14.4@99mph stock. There are Accord owners getting 13.9-14.2 out of these coupes. The autos are about .3-.4 and 3mph slower. It is very much a driver's race, fellas.
Show me proof that accords are getting 13.9-14.2 lol
Old May 28, 2005 | 03:53 PM
kailep's Avatar
next time check the "V6" badge on the rear of the Accord first. If the badge is red color, it is a 6 speed. If it is black, then it is an auto.
Most likely it is an auto because there's hardly anyone buy stick in the Accord. And so if it is an auto, when the guy slams on the gas, his tranny will downshift to 3rd. Therefore, he'll burn you anytime when you have your gear in 5th. Case closed.
Old May 28, 2005 | 04:52 PM
realgone's Avatar
Widdle ya into kindling
This site shows the 2004 Accord Coupe EX V-6 running a 14.5 quarter mile and the G Coupe at 14.2. I am sure with some mods this is possible.
Quarter Mile Times by car
Old May 28, 2005 | 06:23 PM
pfizzle's Avatar
Overall Best 1/4 mile - 7th gen V-6 Automatics
Vis GT 14.2x (N2O)
03LXV6Guy 14.589
AccordEXGirl 14.744
Torqueaholic 14.7x
ck2000 14.831
03accordexv6 14.837
Roadmaster 14.902
mlvswoll 14.98
sandwiches 15.038
Need4Speed 15.093
FinFan 15.1x
Sticmann 15.3x
Overall Best 1/4 mile - 7th gen V-6 6-Speeds
Stoner 14.235
Tman 14.28
6SpeedMaster 14.43
Captal 14.46
Relentless 14.4x
6th Speed 14.579
Scott Si 14.601
6spdaccord 14.665
drdingo21 14.708
Those are members of v6performance.net I have yet to see a 13.9-14.1
Updated
"stoner" hit 14.1 with 2004 Honda Accord EX V6 6 Speed
AEM v2 CAI
GReddy Evo 2
HFP Suspension
V6P Ground Kit
Waiting for Frog Harness for VAFC
Best To Date: 14.130@99.98 (CAI, Exhaust)
Old May 28, 2005 | 08:32 PM
gtbigup01's Avatar
Originally Posted by realgone
that is what I was going to say. The accord V6 are fast, but not faster. The new hybrids are the fastest and I believe those are 250-60 hp.
Do the hybrids come in coupe? If not, the hybrids aren't the fastest, but they do pretty daen good for gas savers. 6.6 to 60 by some mags. One other thing to consider is that only the coupe V6 comes with a 6spd, the sedan only comes with autobox.
Old May 28, 2005 | 08:47 PM
EX-250's Avatar
http://www.roadandtrack.com/reviews/...1_g35_data.pdf
Check top speed in 3rd gear....
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
doakley92
Sep 25, 2015 12:58 PM
