**Vid** g35x 1/4 mile dyno run!
Old May 30, 2005 | 09:04 PM
MrBillMartin's Avatar
REHOSTED g35x 1/4 mile dyno run
Here it is!!!!all you swlabr kinda guys(more vids to the person who tells me what thst means in ur pm box
this one should work.
http://video.freevideoblog.com/Playe...3-DA9C25F0BE14
Old May 30, 2005 | 09:38 PM
g356spd06's Avatar
says link doesn't work =[
Old May 30, 2005 | 09:49 PM
NorCalifG35's Avatar
Same here
Old May 30, 2005 | 10:03 PM
RetAF's Avatar
Here`s what I get
"Unfortunately, the link you have clicked is not available.
Your transfer cannot be completed. Most likely the file has exceeded its allotted bandwidth or has been removed by the original sender or a recipient."
Old May 30, 2005 | 10:26 PM
SGT's Avatar
SGT
http://s48.yousendit.com/d.aspx?id=1...I0UE772P1LC43J
Was I the only one able to download the video? I've reposted it, but it appears that the link will expire after one week or after it's been downloaded a limited number of times, whichever comes first, so be quick.
http://s38.yousendit.com/d.aspx?id=2...Q3UCH1IKZNHM3S
I love the sound of a roaring engine.
Old May 30, 2005 | 10:54 PM
DingoNY's Avatar
Ok so how about the results of the dyno run?
Old May 30, 2005 | 10:58 PM
SGT's Avatar
SGT
Ditto. BTW, MrBillMartin, is that your G35x?
Old May 30, 2005 | 11:06 PM
G35_TX's Avatar
I wouldn't trust the results of this Dyno. Wasn't even done properly. They just floored it from a start and didn't hold it in 3rd gear where it should have been taken to redline and let off, not going through all the gears.
Old May 31, 2005 | 06:45 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Got the vid OK.....I'm also curious 'bout the way the dyno was done. Nice job however....JBX
Old May 31, 2005 | 10:43 AM
ComptechRSX's Avatar
you idiots you didnt read the title!!!! IT says 1/4 mile dyno run... this was after we tested the HP. The place we went to can also use the dyno to see 0-60 and 1/4mile times as well !!! Read the frekain title before you comment on how it was done wrong!!!
Old May 31, 2005 | 10:45 AM
and just for the record it should be 4th gear cause the ratio is 1:1. If you did it in 3rd the resultsa would be inaccurate.
Old May 31, 2005 | 12:01 PM
G35_TX's Avatar
Sorry to say but your a idiot because 95% OF THE TIME a dyno is only used to measure HP not 1/4 or 0-60. Let me remind you this isn't a RSX board full of kids. So your comments aren't apperciated.
G35_TX's Avatar
Well if that is where 1:1 is on the auto then fine. I just know the 6mt its 5th.
Old May 31, 2005 | 12:04 PM
SGT's Avatar
SGT
So what were the results?
Old May 31, 2005 | 07:07 PM
Whoa !, .....Slow down there tough guy. You're right about the very convoluted title being misconstrued, but the CORRECT spelling is F*R*E*A*K'*N...lol Take a pill or something JBX
