slip question?????
Old Jun 11, 2005 | 08:45 PM
LuXXXz's Avatar
slip question?????
ok so im new to this so be patient with me.
ok when im driving and i slam the gas pedal to pass, it doesnt shift right away, first the slip light goes on and then it shifts, is this normal???
Old Jun 11, 2005 | 09:01 PM
G35lips's Avatar
Florida G35 Club Member
Sounds like the vdc is kicking in, that is what is meant to do. You can always turn it off, but make sure you practice in an empty parking lot so you are aware of how the car will react when it is off.
Lips
Old Jun 11, 2005 | 09:08 PM
LuXXXz's Avatar
sounds good thanx for the advice, i know its not always easy in a new car ur not used to.
i appreciate it.
Old Jun 11, 2005 | 09:18 PM
G35lips's Avatar
No prob, do you have a stick or automatic, and if it is stick what gear is the slip light goin on in? I have an authomatic and my light only goes on when I take corners to fast, it is wet out, or if I slam on my gas from a dead stop.
Lips
Old Jun 11, 2005 | 10:59 PM
LuXXXz's Avatar
i have automatic and when i was going 30 and i slammed it, then it turned on.
Old Jun 12, 2005 | 03:06 AM
RocketsRedGlare's Avatar
Uh, y'all do know that the throttle is NOT an On/Off switch, right? There's more positions than on the floor and all the way up.
Old Jun 12, 2005 | 03:35 AM
trey's wife's Avatar
My horns hold up my halo
Were you going in a straight line at the time, or going into/coming out of a corner?
If it's dry, the surface is ok, and you're going in a straight line, I just can't see the VDC kicking in.
Old Jun 12, 2005 | 11:15 AM
G35lips's Avatar
Yeah, what he said. Maybe if the road was wet or your tires are completely worn down.
Lips
Old Jun 13, 2005 | 08:31 PM
LuXXXz's Avatar
i only slammed it cause i wanted to see passing speed of the car, i havent even gone over 90 in it yet and i didnt even slam it from a dead stop yet either.
Mry
Mar 3, 2023 01:03 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
socalg35x
Jul 28, 2015 10:42 AM
newg37
Jul 26, 2015 09:32 AM
