An idle question re: jacking up a car...
when jacking up a car a quandrant at a time, is that stressful on the car? Am thinking there is a fair amount of 'twisting' of the frame while the car is getting jacked up. I don't think it will cause severe damage for a typical time of ownership but nevertheless, can it cause the chassis to creak (make noise) or structurally weaken over time?
C.
Originally Posted by ABQ_G35
I doubt it, your car is subject to far worse "twisting" just driving on most roads and city streets, think about it, plus, most times you go over a driveway one wheel first, the car definitely twists under those conditions, and frequently!
Originally Posted by jasperg35
disagree... - when these movements occur, it's at the suspension level with the parts that are supposed to be absorbing the shock (aka shocks), are doing their job. when you jack up the car, you are raising the car with approx 1/4 the car weight on one point of the frame that has no ability to adjust or compensate for this difference. i am also concerned with the creaking that occurs when i jack up the car. i believe these points are reinforced parts of the frame that expect a certain amount of weight. but that is one reason why i don't send my calipers off to get powdercoated (keeping brake dust away), because my car will have to be on jackstands. and that sound is just scary.
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
To what do you think the shocks are connected? They're not out there just compressing and rebounding on their own.
You won't hurt a thing jacking one corner of the car up, putting it on jackstands, driving onto ramps, etc. The G35, like all cars and trucks today, are so torsionally stiff at the unibody (or frame in a pickup truck) level that you'd have to simultaneously yank one corner up and push the opposite corner down with thousands of pounds of differential force to do any damage.
on base. old military habit... they have these 'hobby shops' that let you take your own car and do your own work, and pay like $5 rental fee and tool use. they've got places for you to change your oil, every tool you can think of, and a lot of the time, someone is on staff to help you out, if you're clueless (like me). i don't know of anywhere else that would let you do this.
Thanks
