Interior A-pillar trim, how to remove?
Old Jun 23, 2005 | 05:37 PM
johnboy00's Avatar
Do you just pull out at the top, then pull up away from dash? TIA
Old Jun 23, 2005 | 07:11 PM
Corgidog's Avatar
If you are removing it because the tanish color doesn't match the rest of the interior, I don't blame you. When I see that crappy looking tan trim on my DG graphite car, I just shake my head in disgust and wonder who in Infiniti thought that one up. It should be the same color as the headliner or the dash. It is tan regardless of what color you get.
Old Jun 23, 2005 | 10:32 PM
johnboy00's Avatar
I want to remove it to run some wiring underneath.
Old Jun 23, 2005 | 11:15 PM
afr0puff's Avatar
Supa Dupa Moderator
grow your fingernails out... stick them in between the trim and the roof liner. Just pull it. It should pop right out. Three fasteners I believe. How thick is your wiring? You can also use a credit card and push it between the trim and the windshield.
Old Jun 26, 2005 | 12:14 AM
ymisotall's Avatar
The reason I was told (why the headliner and A/B pillars are tan) is because it makes the interior less claustrophobic. Actually the salesperson told me this. I thought that was funny but what can we do? I was hoping it was something we can change (as an option).
Old Jun 26, 2005 | 12:30 AM
xswl0931's Avatar
Take a look at other premium brands and you'll see the same thing.
Old Jun 26, 2005 | 11:44 AM
NorCalifG35's Avatar
Yes, that's all you have to do. There are two clips holding it against the metal and at the base of the molding (down by the dash) there's a slotted piece that is shaped so that you need to pull the whole thing toward the rear of the car once the two clips are popped out.
Old Jun 26, 2005 | 01:27 PM
G35Alex's Avatar
Excellent question. I am about to yank mine out....I burned mine with a cigarette......time to start wrapping in suede....
Danielek
May 1, 2022 01:28 PM
nissandrifter32
Dec 22, 2015 04:28 PM
alessandro
Oct 8, 2015 09:29 AM
TNRocker
Sep 21, 2015 08:36 AM
