Installed front Aero Kit????
Old Jun 27, 2005 | 08:22 PM
ydlee24's Avatar
Just installed Front aero kit but ther there is a slight gap between the side marker lights is this normal? And there is a slight off track on the headlights. Does anybody else have the same problems or did the people that installed my aero kit dont know what they are doing?
Old Jun 27, 2005 | 08:43 PM
shodog's Avatar
got any pics? it should fit nice and flush
Old Jun 28, 2005 | 02:50 AM
skeleton_cru's Avatar
Sedan
Is it a genuine OEM bumper or a replica?
Old Jun 28, 2005 | 06:15 AM
ydlee24's Avatar
OEM I remember seeing NISSAN on the bumper.
Old Jun 28, 2005 | 06:48 AM
Sedan
Where did you get it and how much did you pay?
If it is OEM it should fit better.
Old Jun 28, 2005 | 06:54 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I installed mine myself it is perfect.
Alignment should be just as good as the one you took off!
FWIW......
There is a notched clip at the bottom of the headlights.
If they missed the clip it will not align properly,
Old Jun 29, 2005 | 08:21 PM
Sedan
Originally Posted by KYINE33167
i would like to know where to get that front bumper from
You can check with your local Infiniti dealership or find it online.
www.everythingg35.com
www.grubbsperformance.com
www.performancenissanparts.com
Old Jun 29, 2005 | 10:34 PM
kegels's Avatar
Try www.infiniti-parts.com. I just ordered one today - cost me $1055 including shipping. That's the cheapest i've seen for a Nismo front bumper.
Old Jun 30, 2005 | 10:47 AM
ydlee24's Avatar
Fixed the problem had to get the 1 inch square metal pieces on the frame cut in order for the aero kit to fit perfectly.
Old Jul 4, 2005 | 02:40 AM
Sedan
Ummm, that doesn't sound right.
Old Jul 4, 2005 | 11:48 AM
g35guy86's Avatar
where on this site did u find the aero bumper cause all i can find is the regular bumper?
Old Jul 4, 2005 | 11:59 AM
InTgr8r's Avatar
If you call EverythingG35 you can get it for less than $900
Old Jul 4, 2005 | 12:02 PM
InTgr8r's Avatar
Yes there is some square tubing that rejects the sport bumper.
This may have been added in '04.
Just needs to have ~ 1" trimmed off the bottom.
Old Jul 4, 2005 | 12:45 PM
kegels's Avatar
Here's the specific link for the Nismo bumpers -
http://www.trademotion.com/partlocat...&subcat3=75627
I actually called everythingg35.com to see if they would match the infiniti-parts.com price and they refused to. This was as of last week. Maybe they have dropped it since but it's always good to do your homework. I ended up buying mine from infini-parts.com and received the bumper the next day after I placed the order.
Removal of the OEM bumper was straightforward - just time consuming especially removing all the bolts from the undercarriage cowl and the out-of-the-way side marker bolts. You have to remove the metal bracket that holds the side markers from the OEM bumper and re-use it on the Nismo bumper. They are riveted so you will need to drill out the rivets or get a rivet removal tool. In my case, I just popped the bracket out using flat screwdriver - basically destroying the OEM bumper - and drilling the rivets out. I did not use rivets to mount the brackets but ended up using bolts/nuts/washers to place it on the Nismo bumper. Easy removal if the need arise in the future.
