30k maintenance - injector service
Old Jun 29, 2005 | 10:55 AM
townsley's Avatar
Question 30k maintenance - injector service
Took my 2003 sedan in for its 30k service. It cost $420 and they tried to up-sell me for some injector and throttle body service. I'm guessing they put some additive in the gas to clean the injectors and the valves. They also must spray something on the throttle body to clean it off.
I declined that service, for which they wanted $168, in favor of doing it myself. Anybody know what sort of additives or solvents I should use?
BTW - the pictures they showed of fouled injectors, valves, and throttle body were hilarious - as if the car had been breathing nothing but tar for weeks.
Old Jun 29, 2005 | 12:10 PM
Q45tech's Avatar
1-2 cans of BG44K in the gas tank, 1-2 small cans of BG throttle body spray cleaner and various brushes and rags and effort.
To clean the plenum and runners above the injectors you need a BG vaporizing spray system.
http://bgprod.com/products/fuelair.html
Old Jun 29, 2005 | 12:15 PM
cato's Avatar
SouthernComfort Moderator
I opted to pay for that service at 30K. After the TB service, the car seemed to accelerate better. At 60K I did not have the service done. When I installed my 3/4" Motordyne plenum spacer, I noted a bunch of crud around the TB. I took a rag and scraped some of it off, but I have no idea how to actually clean the TB. Anyone know how to do this properly?
Old Jun 29, 2005 | 02:09 PM
townsley's Avatar
Q45Tech - thanks for the advice. With what frequency should the plenum and runners above the injectors be cleaned? I don't recall seeing that on the list of services they offered. Also, the system you reference requires an air pump. Do you know of any alternatives for those of us without compressors?
Old Jun 29, 2005 | 04:18 PM
Msedanman's Avatar
O.F. Administrator
I've read that this is real good to have done periodically to keep the injectors and intake clean and optimum. They say it pays for itself in gas savings.
As far as cleaning the TB, they say not to rub it with a rag......?????? just to spray cleaner in and let the engine suck the dirty crap on thru.
C.
Old Jun 29, 2005 | 09:16 PM
skeleton_cru's Avatar
Sedan
I did the same, but since my engine failed about a month after the service I paid for nothing. At least I got a new engine out of the deal.
Old Jun 29, 2005 | 09:18 PM
sonofsnood's Avatar
what did they do for your 30k service?
Old Jun 29, 2005 | 09:38 PM
townsley's Avatar
The 30K service included:
Replace Eng Oil & Filter
Replace Air Filter
Replace Engine Coolant
Replace wiper inserts
Test horn, lights, wipers
Rotate Tires
Correct Tire Pressure
Clean sunroof drains
Adjust parking braks
Replace microfilter
Inspect fuel and vapor lines, drive belts, brake pads & disks, transmission fluid, exhaust system, suspention, stearing gear
Correct fluid level on brake fluid, power steering battery, window washing fluid, rear axle
lubricate door latches and hood hinges
Wash & vacuum
Yeah, it was pretty much a ripoff. If they hadn't replaced my front pads and rotors, I'd have been a lot more disappointed.
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
