Does the dealer charge for alignment/balancing?
Old Jul 2, 2005 | 07:51 PM
KEVIN97A4's Avatar
the reason I ask is that at highway speeds the steering wheel in the g35x vibrates more than it should for a car with 8k miles on it...seems to be a balancing or alighment problem to me...will the dealer charge for this? anyone know?
Old Jul 2, 2005 | 08:00 PM
Msedanman's Avatar
O.F. Administrator
I think you're covered for balancing and alignment for the first year or 12k miles. Talk to the dealer.
C.
Old Jul 2, 2005 | 08:01 PM
KEVIN97A4's Avatar
does anyone know for sure...that way when I call to make the appt I know exactly how to deal with them if they want to charge me. thanks in advace.
Old Jul 2, 2005 | 08:31 PM
Msedanman's Avatar
O.F. Administrator
It's in my 'Warranty information Booklet'. -- 12 months 20,000 kilometers (12000 miles)
C.
Old Jul 2, 2005 | 08:37 PM
NorCalifG35's Avatar
Don't waste your time taking it back to the dealer. Yeah, they won't charge you but they can't balance tires for s***.
I had the same problem with mine and let the dealer try 3 times to fix it. They couldn't because they're simply "spin balancing" them.
Take your car to Discount Tire/America's Tire and ask them to "road force balance" your tires. They use a special balancing machine that the dealer doesn't use.
Road force balancing cost me $60, but the shimmy/vibration is now gone at highway speed.
Old Jul 9, 2005 | 12:34 AM
KEVIN97A4's Avatar
I'll let u know what happens after I let the stealership try it once
Old Jul 10, 2005 | 09:17 AM
Q45tech's Avatar
Strange: For the last 15 years I've [paid] rotated and balanced my Michelin tires every oil change [90 days 3500-4,000 miles] and they still change a little every 1500 miles.
But then again most people are not very sensitive to the slight quiver that a few grams out [5-7 grams <1/4 ounce] can produce.
When new tires are installed they should be rebalanced at the first 400-500 miles as they change in the beginning at a rapid rate.
Old Jul 22, 2005 | 04:32 PM
KEVIN97A4's Avatar
So I finally had the dealership take a look at it...they balanced the front wheels (they said they were pretty bad, probably because of the potholes) and they replaced my front brakes (insane squeeking noises) and tightened a rear lug nut to correct torque specs (clicking sound when taking off) everything seems fine now....They washed the car and changed my liscense plate frame to theirs..(that was sneaky!)
Old Jul 22, 2005 | 10:00 PM
heeb's Avatar
I've got terrible shimmy and vibration at any speeds over 40 is where it is noticeable. At 70-80 it is absolutely unnaceptable, but this may be because I put on new wheels and tires.
The dealer just fixed it for free under warranty work? I dont understand. Is it included in the warranty to do an allignment and balance after a certain amount of mileage? If so, maybe I can talk my dealer into doing one for me a little early (8800 miles)
and LOL at the changing the license plate frame to theirs!! I find that hillarious! What happened to your old one? They just kept it?
Old Jul 23, 2005 | 11:46 AM
trebien's Avatar
Gee... you think? So you put on new aftermarket wheels and tires, but you expect the dealer to balance your tires for you for free because you now have a vibration?
Yeah - let me know how that works out for you.
Old Jul 23, 2005 | 12:09 PM
KEVIN97A4's Avatar
Yeh they did it for free.(I dont think they alligned them..just balanced)..I only had like 8300 miles on the car. Dont know if they will do it for aftermarket wheels for the reason Trebien said...as far as the liscense plate frame....yeh they kept them...I guess they threw them out since they were from a competing infinity dealersip....not that I care..They treated me nicely and got everything fixed....
jeffbdye
Jun 1, 2018 03:51 PM
