ebay auctions 2" drop and Brembos
http://cgi.ebay.com/ebaymotors/ws/eB...category=33564
http://cgi.ebay.com/ebaymotors/ws/eB...category=33582
2" drop front 1.3" drop rear 157.00
Better Life thru Chemistry<P ID="edit"><FONT class="small"><EM>Edited by merlin on 06/17/03 12:51 PM.</EM></FONT></P>
Re: ebay auctions 2" drop and Brembos
If the specs hold true on those springs 6.4kg and 4.9kg front and rear spring rates are a tad on the weak side for such a drop. Everyday normal impacts will have you on the bump stops all to offten, no thanks. And what's up with the running lower rear rates, not good either. Those spring rates in lbs are 378lbs and 289.
Ivry 6mt sed
Injen CAI, 22" resonator
8X18 Enkei RPM2 45mm
Kumho MX 245/40
clear corners
Ivry 6mt sed
Kumho MX 245/40
clear corners
The Brembo's are exactly what is on my sedan. Get them, the price is incredible!!
[img]https://g35driver.com/rides/spec/pix/G35Spot_1033265073.jpg[img\]
https://g35driver.com/rides/detailri...dx=1&vehId=182
Frank
CM Motorsports
Frank
CM Motorsports
