Questions regarding tire tread width...
Old Aug 15, 2005 | 12:23 AM
mikeee2's Avatar
Originally Posted by doogie
It was a long time coming but I figured I should do this before the 245's are gone.
Sorry for the weird colors and stuff, I had to touch up the image so that the tires were a little more clearly defined, and as a result the rest of the image suffers. Hope it helps anyways.
Image 1 from back
Image 2 from back
The 2nd picture looks pretty beefy from the back. Nice!
You know...because the sedan is quite skinny and the tires are tucked in a bit, it takes quite a wide tire to make it look beefy. Whereas cars like a basic 325i, they have a fender flare and their offsets lines up right by the fender, the same tire width on a 325i looks more meaty than a G even if the G has wider tires.
If you look at the back of a 350z, the tires itself are not that big but because it's so wide, your preception of the tires are wideeeeeeeeee just because the body is wide.
Old Aug 15, 2005 | 12:59 AM
doogie's Avatar
I think it has a lot to do with wheel offset too.
Of course, with some wider wheels and a set of 275s I bet the sedan would look like a Bulldog too.
Old Aug 15, 2005 | 01:23 AM
mikeee2's Avatar
The 17's are tucked in with offset 45. What's the correct offset so it lines up right by the fender? lower or higher than 45?
Old Aug 15, 2005 | 11:53 AM
vodkarocket's Avatar
Modded Member
I will have pics of this by the end of the week.
If you are looking for a beefy tire, check out the BF Goodrich KDW2's. They have great performance, and even better reviews.
bu villain
19 Inch
Nov 15, 2015 09:23 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
nascarbuff17
Jul 16, 2015 10:23 AM
