Two annoying sounds inside cabin new G35x
My center console creaks when I brake too. Sometimes quite loudly, sometimes not at all. Sometimes it's so bad that it's obviously something that warrants fixing, as opposed to just being a picky owner.
Already my dealer has tried 2 times to fix the creaky metal trim over the shifter. Both times it stopped for a few days then started again.
I'm thinking now that I am better off waiting for Infiniti to issue a TSB on it then get it fixed. Otherwise, they simply pull the trim off and snap it back on which will probably fix it for a few days.
Too bad they don't have a 2005 TSB for the clicking noise high on the driver (and passenger) side window.
These two noises seem to be very common according to this forum.
Hope Infiniti is working on TSBs to fix those.
Creak from door - I found-out that on my 05, the noise came from what holds the tweeter speakers on top of the door. Took me a while to find it since everyone here complained about a noise from the air vent so I kept checking the air vent assembly but that was not my problem. If you look at this little triangular assembly that is holding the tweeter on front doors, you notice that it is very poorly designed and gets loose. I have not fixed this yet since I have to open the door panel completely to get to it.
Noise from the dash/clock assembly -- this one was very annoying and I could hear it all the time. I took it to dealer and they fixed it in a couple of hours.
I agree, for a high end car, and especially after only 2-3 months, this is way too much creaking and noise.
I've owned a BMW and an Audi and they also had noises that drove me crazy. The Audi was the worse, the little fan inside the air conditioner module would rattle after 2 years. Under warranty it was fine but I didn't want to keep the car past that. They replace the whole air conditioner module to fix that little fan. It's probably a $600 fix including labor.
My point is the G35 rattles a bit more than the high end competition but it's not that bad either.
Having said that, my driver side window click and the center console creak are driving me nuts. How can they be perfectly silent on some trips yet creak like mad on others.
Surely Infiniti must know that those two noises are causing much more than the average amount of service visits. Hope they devise a TSB to fix them.
Originally Posted by valero
anyone have experience having these sounds fixed by the dealer
I took the car in and they fixed the console squeak...but my driver side door panel they can't seem to fix...I'll be taking it in a 3rd and actually have one sit next to me while I drive it to point out exactly where the sound is coming from.
Originally Posted by inTgr8r
I had a really annoying sound on the way to work this morning..........
(must have been the 5 alarm chilie last night
.......sorry, couldn't resist.
).......sorry, couldn't resist.
Originally Posted by hgiljr
Welcome to the G35 world. Creeks and Squeaks all over. I have the same issue. I have two different squeaks, one coming from the B Pillars and once coming from the front doors. Sounds just as the TSB states but they are the front, I wonder if it is the same fix? Sound is there with the window up but once you put it down, sound is gone. Hmmm...
I really hope Infiniti fixed this issue - in the new photos it looks promising but a personal inspection/drive will tell.
Quick Window sqeek Fix
My rear windows squeek as well, I had taken it in a few times (Less than 10k miles) and they "Shocker" could not replicate the noise. I however seem to have no problem doing so. I have seen the bulletin in in the thread above, but my quick fix is to just roll the windows down a bit and then back up again. This must put new pressure on the window regulator bolts and takes the sqeek out of the doors for the time being. Only a remedy for the short term, but sanity only comes in small does.
