Installed D specs-Have a question
How to tighten nut at top of shock piston? The rod just spins in the shock. I think this may be the cause of the slight rattle I have. Any help much appreciated! (yes I searched)
while you tighten the nut.
It's easiest to do off the car.
To do it on the car you need a deep offset box end wrench so that
you can use the spanner at the same time.
A socket won't work.
Mine was more of a bump sound than a rattle.
Hope it helps.
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
RA102223
Aug 15, 2015 09:24 PM
