Installing Splash guards
Old Aug 11, 2005 | 03:26 PM
henry_mark0's Avatar
Should I necessarily drill holes in my car ( as per the instruction supplied) to install my splash guards..... Is there any other alternative....
Old Aug 11, 2005 | 03:33 PM
GeeWillikers's Avatar
Walking The Fine Line...
Drill the holes - it makes for a very nice, tight fit. I did mine myself, it was not difficult at all, and all the holes drilled were into plastic - no metal. You only have to make a hole big enough to hold the little metal attaching clips.
The first one took about 15 minutes to position & establish how I was going to follow the process, then the rest went on in a flash.
I hate drilling into my car too, but in this case it was really no biggie.
I would put the car on a lift if you could - it made lining up the underside holes much easier. I lifted my car and pulled the wheels off - it made it a piece of cake.
Old Aug 11, 2005 | 04:11 PM
Nickk6's Avatar
Do you guys or anyone else know where I could get these mudflaps the cheapest? I know everythingg35.com, are they the best priced?
Old Aug 11, 2005 | 04:53 PM
everything35.com thats where I got mine....
Old Aug 11, 2005 | 05:08 PM
tju317's Avatar
Same here, price is good too.
Old Aug 11, 2005 | 05:14 PM
Lip's Avatar
Lip
Curious, I have the 05 splash guards for my 05- Took them off.
Anyhow, does anybody know if the 2004 splash guards will fit on the 05s?
I would have the bottoms painted if they did.
Old Aug 12, 2005 | 12:32 AM
Nickk6's Avatar
Old Aug 12, 2005 | 01:24 AM
sd_diver's Avatar
EverythingNissanInfiniti discount
Found this on the web:
"Like the name says, EverythingNissanInfiniti can get you just about anything you want or need for your Infiniti - OEM parts, accessories, or performance products. The Infiniti Car Club of America has negotiated a 25% discount off retail prices. Mention your club affiliation when ordering."
Old Aug 12, 2005 | 08:47 AM
At the time I bought mine, Grubbs was cheaper and offered free shipping. I have no idea what the deal would be there now.
Old Aug 12, 2005 | 10:08 AM
tonyj's Avatar
My 05 does not have the flaps on it, but I have considered getting them as well. Do you think they look good on the 05, does it distrupt the lines of the car, and do they work well. Thanks
Old Aug 12, 2005 | 12:41 PM
Lip's Avatar
Lip
Originally Posted by Nickk6
I have a set of 05 splash guards, though I never drilled into the body, just used additional tape. I removed them because they are decorative and not very functional-
The 04 and older splash guards were of a different design and functional.
Old Aug 12, 2005 | 01:03 PM
I think they look great, and functionality is perfect. I used to spin the water and crap up off the road into the splash zone right behind the wheel well. Not anymore. Spotless.
Tire dressing that used to spin off into the same area now ends up on the inside of the splash guard - not my paint.
My vote = 10 of 10 stars. Looks great, works great, piece of cake to install. Again, the holes required go through PLASTIC - you're not drilling your metal. You need the holes to accomodate the push-pins and screw clips required to give the flaps that tight, "of-one-piece" look that Nissan intended. I found the installation to be very easy and thought Nissan did a good job with how they attach this accessory to the car.
Previous model year flaps don't fit the 05 properly as far as I know...
Old Aug 12, 2005 | 03:14 PM
lelg35's Avatar
I almost got the splash guards on mine (an 05 sedan) because I wouldn't mind the extra protection...but when I started seeing some sedans on the road with them on...it just didn't appeal to me (really, it was the front splash guard that I didn't like...the rear one looks ok). I'm sure they offer great protection (especially the rear ones that extend pretty far back), but I think it ruins the lines of the car. Just my opinion. I ended up telling the dealer to not put them on when I took delivery. Go take a look at some with them on and without and see how you like them.
Old Aug 12, 2005 | 03:30 PM
Many more opinions:
https://g35driver.com/forums/showthr...=splash+guards
Old Aug 12, 2005 | 04:24 PM
Nickk6's Avatar
I am a bit lucky, the guy that works across the street has a 05 DG Sedan with sport package and splash guards, so I can see my car with and without them....they don't take away anything from the look in my opinoin, so the functionality is why I am getting them.
