Vibration in upshift from automatic - 2005 G35x
Old Sep 12, 2005 | 03:18 PM
RLampke's Avatar
Question Vibration in upshift from automatic - 2005 G35x
Has anyone experienced occasional rough shifts from the automatic when it shifts from 1st to 2nd gear - usually under medium or heavy acceleration...? Once in a while, if I decide to give more throttle while moving, say @ 5 mph through a toll, and then suddenly increase the throttle; the car will shift roughly from 1st to 2nd gear only. It will actually vibrate and shake the entire dashboard during this instance - again it only happens once in a while and will happen w/or w/out the A/C on.
Comments...?
Old Sep 12, 2005 | 03:34 PM
GeeWillikers's Avatar
Walking The Fine Line...
The only harshness I've experienced is in manual mode under hard acceleration. The 1-2 can be a bit firm, but nothing like what you describe.
Other than that it's like a baby's behind.
Old Sep 12, 2005 | 03:43 PM
dallasg's Avatar
I've noticed some of what you described - but only with the 2->3 shift. In full auto I sometimes feel vibration if i'm adding throttle during the 2-3 shift. In manual mode it's not vibration, it's a hard shift that seems to shock the drivetrain under certain throttle conditions.
Old Sep 12, 2005 | 03:57 PM
RLampke's Avatar
Ya, this is different than the manual mode "quick shift" that happens under hard acceleration at times.
Old Sep 12, 2005 | 04:14 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Nothing like you describe, but..
I've noticed that you can fool it & cause a rough shift.
When accelerating, if you ease off a little ( ie slow traffic)
& happen to shift up, it can be kind of rough.
Old Sep 13, 2005 | 07:24 AM
mickey3c's Avatar
The only rouch shift i experience in my 05 x is from 2-3. Seems to happen more when it is cold but I have gotten it to happen after about 20 minutes at 75...
gatorglaze
Sep 10, 2015 12:03 PM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
migurus
Sep 5, 2015 09:39 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
kevintandmd
Sep 3, 2015 06:41 PM
