Goodyear Eagle F1 GS-D3
Originally Posted by erikill
now how would the F1's compare to for instance a Michelin Pilot Sport's or the Avon's? I've been reading up on all of them and just curious about everyones opinion / experience.
F1's are very comparable to the Pilot Sports overall, maybe superior in all out handling, maybe a little lower on the quiet/ride side.
Avons are excellent road tires, less flat out performance though, than the other two.
My $0.02
I had them on the car, in the end when temps got to 90 degree's and above they have the unforgivable habit of becoming loud when I'd try and hot foot the car. Theirby calling attention to the whole world that I was having fun, no thanks.
Originally Posted by Gdup35sedan
I have 245/40/18 Bridgestone S0-3 pole positions on my stock 05' sport pack wheels. 245/40 is the closest size you can get to stock with not really affecting the speedometer. If you the speedometer reads 65mph you are really going 64.2mph with the 245/40's. You could probably also get away with a 245/45/18 or a 225/45/18 depending on if your car is lowered or not. Go to tires.com, then go under the info center and click on the tire calculations and enter your info. It will give you all the dimensions and differences of the stock tires and the new tires in whatever size you choose. Hope this helps
I have had these tires on my car for a while now. 245/45 all the way around.
Very quiet tires...blah blah.......what most people have said already..sticky...etc...etc.
I will be buying them again when the time comes
Originally Posted by doogie
> 50 degrees?
Best tires ever, wet or dry. that's all I have to say
< 50 degrees?
You need to look elsewhere
< 50 degrees?
I love in FL also. i have 245/45 18 on my sedan. I also have 13k on my F1s and they will be done around 16k no question. They handle good however they are heavy as ****. 29lbs a tire. I am going to get some PS2s in 245/40 18 on my next set which are 24lbs a tire. My stock wheels/tires weighed 47lbs and my current setup with the F1s is 50lbs. Good tire but it is very heavy. besides from that no complaints.
Originally Posted by ryoken
I ran a set of these on my car, 225/55R17's, before they made it in a 235/50R17..
Thanks.
Originally Posted by Teeter
I don't think 245/40/18's are a good fit for the 7.5" wide stock Sport rims. The mfg's all seems to recommend at least an 8" wide rim for that size and I agree. Performance declines quickly when the sidewalls are bulging rather than standing vertically. 245/45/18 is a better fit for the Sport rims, and they get you within 1.3% of the correct speedometer reading. -T
Yeah I think 245 is a little wide for 7.5'' rims. If I couldn't get the tire I want in 235/45/18 I would probably go with 235/40/18 or 235/50/18.
Originally Posted by blackonblackG
245/45 = 1.3-5 % larger then OEM = slower. that is one of the reasons im going with 245/40 which will be a bit better for performance.
Not to start this debate again, but larger does not equal slower. In fact, theoretically, larger should be faster. You'll cover more ground for every revolution. -T
Larger = higher top speed, slower accel.
i am on my second set of the GS-D3's with the G sedan, first was 225/55/17 now I am running 225/50/17.
for the first 10-12k miles these tires are superior to S-03's, michelin and other max performance tires available in our sizes. after that they are merely equivalent.
straight line traction is the main area that drops. cornering never really deteriorates. In rain (hell even snow, i have run em in 4 inches of really wet snow and up to 6 inches of dry powdery stuff) is almost as good as dry pavement.
I got 21k miles on the first set, I am at 13k miles on this set with 50+/-% left.
They have seen drag strip, road course, day to day and serious canyon runs. I have run 235/50/17 pilot sport and pilot sport a/s's on an altima as well and like has been said, ride quality is the only place michelin has the goodyear. And that is not by much.
I was watching spikeTV today and there was a car and driver test with five different sets of tires on the new bmw 3 series. Don't remember what the others were but in overall on wet or dry, first place came this goodyear eagle tires. So I guess they are very good tires, and also it was cheaper than most of the competiters.
I rotate my tires every oil change. I also religiously maintain 45 psi front and 43 psi rear.
The first set was replaced at 21 k miles and they had just gotten to the wear indicators on two of the tires.
That set saw two roadcourse events and three or four dragstrip appearances, some *** sliding, but no doughnuts or burnouts. Still got the scuff marks on the ceiling
