VQ35DE in 03 Sedan 6MT
Old Oct 6, 2005 | 11:11 AM
Phildo's Avatar
Does the 2003 Sedan 6MT have the VQ35 or the VQ35DE engine? All coupes, auto or manual seem to have the DE.
Old Oct 6, 2005 | 11:25 AM
Phildo's Avatar
From what I have read, the D stands for DOHC and the E stands for Multiport Fuel Injection. The Sedan has both of these features, correct? Infinitihelp.com says the sedan is a VQ35 and the coupe is a VQ35DE, that's why I ask.
Old Oct 6, 2005 | 03:07 PM
some.devil's Avatar
From infinitinews.com
VQ35 3.5-liter DOHC 24-valve V6 with aluminum-alloy block and heads and molybdenum coated pistons
Displacement
3.5-liters
Horsepower
260 hp @ 6,000 rpm
Torque
260 lb-ft @ 4,800 rpm
Bore X stroke (mm)
95.5 X 81.4
Compression ratio
10.3:1
Induction system
Sequential multi-point fuel injection
Valvetrain
DOHC 4-valves-per-cylinder, with Continuous Variable Valve Timing Control System (CVTCS)
Recommended fuel
Premium unleaded
Emissions system
Performance exhaust and three-way catalytic converter with closed loop feedback and electric dual-mode muffler
Platinum-tipped spark plugs
Maximum engine speed
6,600 rpm
Old Oct 6, 2005 | 03:23 PM
3point5SE_Auto's Avatar
G35 coupe, G35 sedan, M35, i35, fx35, murano, xterra, pathfinder, quest, 350z, altima 3.5, maxima, all have the VQ35de with minor variations in intake/exhaust systems and cams. timing/tuning is the only real difference between the various cars.
the frontier has a bored out vq with 4.0 liters of displacement
This vq35de is a modified version of the vq30de found in earlier maximas/i35.
it is not the same as the vg30de found in earlier 300zx's.
other engines in nissan's stable are qr25de (sentra/altima), vk45de (m45, fx45, q45), ca18de (sentra), sr20de (sentra), and the 5.6 liter in the titan/armada/qx56
Old Oct 6, 2005 | 06:18 PM
BbyG35's Avatar
In body style, V35 designates the Sedan and CPV35 designates the Coupe. Same engine used in both as 3point has already stated.
tiguy99
Mar 1, 2016 11:42 AM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
TheKnite
Aug 14, 2015 07:59 PM
